Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
E000 in IR3300
When machine starts E000 on screen & Copier is auto Off within sec.
Plz. give me solution
aashish.canon gmail.com
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 89 Answers
Can clear error in service mode but best to get a trained tech to come and fix.
Posted on Jul 30, 2009
I am having problem with IR3300 of code E000-0000 give me solution
Hi
I found your problem here:
Error Codes Canon iR3300 Code E000 0000
and it seems to have a number of alternatives. And also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine, and this might be a good idea as it will almost certainly explain how to do the repairs..
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 02, 2015 | Canon imageRUNNER 3300 All-In-One Laser...
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
The temperature of the fixing film is as follows:
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
Tip
Error code CANON iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E000
0000
E001
0000
0001
0002
E002
0000
E003
0000
0001
E007
0000
E010
0000
on Dec 18, 2009 | Office Equipment & Supplies
CODIGO E000-0320
The E000 means that You have problem in fixing section and 0320 means that when the temperature is 160 deg. C, the temperature remains the same instead within 4 minutes it must rise for 10 deg.C in lower heater.
Probable cause's can be:
  • faulty thermistor
  • faulty fixing heater
  • faulty DC control pcb
  • faulty AC control pcb
  • oil thermistor
The best solution would be You to call service. If You want service manual, write me on emma.servis@gmail.com.
Feb 12, 2011 | Canon CLC 4000 Copier
Sir; i have a canon ir 6000i model machine
these is often sympthom when there is fixing trouble, usually when there is error code like E000, E001, E002, E003...
If you want send me e-mail on emma.servis@gmail.com for service manual.
Aug 03, 2010 | Canon imageRUNNER 5000 Copier
Heater Unit & Hard Disk problem ir3300
1) what kind of hdd failure? Did copier report error code like E602-0003, or? When the hdd error occured did the service exchange HDD with new one and upgrade the system. Other thing, but not mostly likeble, check the current in el. insert.
2) Wich kind of problems? Did the copier reported E000, E001, E002, E003,..., is there was smudged copies, paper jams,..., how did you solve the problem? Did the service replace fixing film unit, or complete fixing unit? Do you have enough air flow around the copier, is the copier beneath the air conditioning device, is there any air draft,...?
If you want you can contact me on emma.servis@gmail.com, for more help.
Feb 24, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Dear sir when i start machine ir3300 i get code
I.e. Teflon problem if u getting the paper jam in fusing unit every time teflon is cutted in fuser unit is getting prints after meachine on and off, problem with the sensor u cleam it that's work fine. for any information plz mail me e-Mail : meda.purushotham@gmail.com, 919290062654
Feb 23, 2010 | Canon imageRUNNER C3200 Copier
Sir,error E00007-0000 displayed on screen of canon ir3300 when i give it a printing command.
E007-000: An error in the rotation of the fixing film is detected.
Get a tech to service your copier.
Nov 14, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
E000 error message on canon imagerunner 2000 copier
Hello.
E000 means :
"The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
Jan 19, 2009 | Canon ImageRunner 1600 Copier
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
Computers & Internet Logo
250 people viewed this question
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
Tony
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
