Question about Canon imageRUNNER 5000 Copier
Can't print or scan through USB port on Canon imageRUNNER 5070.
SUMMARY:
Canon imageRUNNER 5070 with USB port. Is USB port active by default, or does it require software/hardware modification? When connected to a PC through the USB port no device is detected.
IN DEPTH PROBLEM DESCRIPTION:
My office has a Canon imageRUNNER 5070 copier, and we want to be able to print and/or scan via the USB port on the copier (located below the RJ45 port).
Currently we CAN print/scan via our network, but we would like to be able to do so locally, if possible.
When a computer is connected to the Canon imageRUNNER 5070's USB port, the computer does NOT see any device at all, so I am wondering if the port is even activated.
  • gandalf_gree Apr 20, 2009
    Thanks for the suggestion, gunninfo. I've looked under the hardware tab, but the printer does not show up at all (not as disabled, or problem or anything). I've tried starting and restarting the printer. I've tried two different USB cables. I've tried installing the printer drivers. Still, no luck.
    Any other thoughts or suggestions are welcome!
    Thanks,
    J
  • 59 Answers
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Posted on Apr 20, 2009
Cannon ir 1023 will not scan in windows 7 64bit
For the scanning you have to use the USB port and load the Tool Box 4.9 scanning software on the CD or from the Canon site. If you have commercial scanning software you will have to use the Scan Gear software as an interface between the scanning software and the copier.. Good Luck.
Aug 20, 2012 | Canon imageRUNNER 1023iF Black and White...
Our network wont see our ir330 imagerunner for printing or scanning yet i can ping the printer and get a reply. i have not installed any software yet for the printer. should i install scangear?
the machine has the print server board and interface board installed? Canon machines need additional hardware installed to function as printers
the parallel port is not a print port
contact connecticutcopierrepair.com for more info
Feb 02, 2011 | Canon (6981A002AA) for imagerunner 2200,...
CANON 5070 IMAGEWRITER POSTING "WASTE
To remove the recovery unit, open the upper right door & remove the developing unit. Be careful to unplug the toner sensor at the front frame. The plug will be damaged otherwise. From the front remove all the corona units. Slide out the fuser drawer. Remove the retainer screw & lock in the drum shaft. Slide out the imaging unit.
The recovery can now be removed.
Jan 20, 2011 | Canon imageRUNNER 5000 Copier
Canon ir2016 TROUBLESHOOT printer problem
Hi mate,
Prior to the issue you facing currently seem like ,
1)have u put the printer driver as default.
2)have u point to the correct printer port at the driver.
3)at the driver advance setting ;get the device status then reboot the machine .
GOOD LUCK MATE......Kindly RATE ME!!! Thanks YOU.
Sep 26, 2009 | Canon ImageRunner 2016 Copier
Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Jan 02, 2009 | Canon imageRUNNER 5000 Copier
Printer keeps pausing itself!!
dev_24ind: The parallel port cannot be used for printing by default. Heaps of people have made this mistake. You need a N Boot Rom installed and N system software. Almost certainly you don't.
Get a Network Multi PDL Printer Kit C1 for IR3300 (contains N Boot Rom and NIC aka ethernet port). A technician can install this and update system software and you will be able to print. You will be able to print over a network (which is the preffered option) use Remote User Interface and Pull Scan using Canon Network ScanGear (google it).
Aug 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
Problems Printing from PC to Copier
What type of driver are you using? Postscript or PCL? Are you printing over TCIP port or a direct connection like a USB? Are there any updates for the Imagerunner since you bought it? They release updates like microsoft releases updates. Also what type of operating system do you have?
Aug 06, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
1,426 people viewed this question
old marine
old marine
