Question about GE Refrigerators
GE artic psc23ng side by side water issue... First the water stoped working... last night the water driped a little then stoped... later it woke me up spraying all over my kitchen floor... any thoughts? Thx
  • 1462 Answers
SOURCE: GE refrigerator
this may be water from the defrost cycle. if this drains to tray over compressor, check tray is not too full (water evaporates from heat of compressor) otherwise defrost water will go to a seperate container which may have a split or is overflowing. fault can also be caused by poor door seals which would produce too much ice on evaporator pipes
Posted on Mar 21, 2007
  • 1073 Answers
SOURCE: Kitchen Aid Superba side by side
check the relay on the compressor
Posted on May 16, 2008
catriver
  • 878 Answers
SOURCE: My Maytag side by side
Ukoni, the drain tube for the defrost is frozen over or clogged. When the unit goes into defrost the water is running out through the front instead of down the drain tube. You can try to pour some real hot water with a baster to clear the tube. Remove the lower basket and at the bottom of the freezer panel in back is where the drain line is located. Catriver.
Posted on Jun 10, 2008
landsend
  • 1066 Answers
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Posted on Mar 27, 2009
  • 42 Answers
SOURCE: I have a GE Profile Arctica. Refrigerator side
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 29, 2009
GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Dec 20, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
I woke up last night with water running from under my refrigerator flooding my kitchen & basement. What could be causing the problem? Also how do I remove the evaporator pan? So much stuff is...
check and make sure that the water fill valve does not have a crak in it usually not enough water in the defrost pan to cause any kind of flooding issue. it is either a bad water valve or a broken water line somewhere on the unit
Sep 08, 2010 | Kenmore 54383 Side by Side Refrigerator
I have a GE profile Arctica with side by side doors (psc23ng). There is a valve at the bottom rear right (facing the refrigerator) with seperate red and blue connections for water. It appears to be a valve...
That sounds like the water valve that receives water from your house plumbing and sends it to your icemaker and to the water dispenser. In addition to the hose connections, there are likely some electrical connections on it.
The valve should be readily available at any of the appliance parts places that sell on the internet. It should be fairly easy to replace. Most of those are pretty accessible.
Oct 20, 2009 | GE Profile PFS22 33" Artica French Door...
Water driping inside from ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile bottom freezer - too warm both freezer and fridge
I found this post online and i have the same issue with the same freezer. Did you ever find out what to do with this?
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Ge PSW26LSRDSS side by side the water line freezes
The water line keeps freezing going to the ice maker? The line in the freezer? Is there alot of ice build up around the fan because of this? If so, it sounds like an ice maker malfunction is the root of the problem, and that can cause evap fans to go bad.
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge 1
is looks like you need to trouble shoot *********** board is this unit has one i can see if i can fix it for you bu i need more info how old is it is it side by side let me know call 562-688-3627
Sep 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
