Question about HP OfficeJet 6110 All-In-One InkJet Printer
I shipped my HP 6110 from England to Canada. The power adaptor accommodates 220 to 110 voltage, so no problem there.It turned on fine. Now the scanner works, but the print cartridges are stuck in home position and the display reads "Open door.Remove carriage jam and then press enter." There is no paper jam nor any debris in the paper path.I went through all the steps on the hp site, but the message keeps appearing. Please help.
  • 1 more comment
  • bosco_desouz Apr 20, 2009
    I cant access the cartridges to remove them.
  • bosco_desouz Apr 26, 2009
    Already did that, without success. I have now gained access to the print cartridges, removed and cleaned them, but still get the carriage jam message.Also gives a message CHECK LEFT CARTRIDGE, off and on.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Remove print cartridges and buy new ones..
    President:
  • HP Master
  • 1,996 Answers
Make sure you actually opened the rear door and reseated it even if there's no visible jam.
Make sure the front panel is correctly installed.
Try resetting the printer by turning it off, unplugging the data and power cables for a few minutes, then plugging it back in and turning it on.
If you've tried this and followed the steps given by HP in a search of your model for "Carriage stall resolution", available here
you may have to have a tech take a look at it...
Posted on Apr 20, 2009
  • efs_perpends
    efs_perpends Apr 26, 2009
    Did you follow the instructions in the link provided (click here) to open the print carriage access door by lifting the handle until the door locks into place.
    Perhaps you have already resolved this issue.
Can i use my wii i brought in england in usa
I believe England uses a PAL system as USA / Canada uses NTSC. You'd have to set your Wii settings to compensate. Also, power outlets in England are different from outlets in North America. You'd also need a new power adapter.
Jan 05, 2011 | Nintendo Wii Console
I purchased nokia3710 from canada.can i use it in india.it is having sim card right now.me in canada now.can i charge it in india as the voltage is different thear.please advise
Hi buddy , You can surly use it as all the mobile charger has an adaptor which will take care of the voltage difference . The electrical circuit (Clamper and clipper circuits) inside the adaptor is so designed that it will allow only a particular amount of current and thus voltage regardless of the input power . So dun't worry . For any quires write back to me .If yo are satisfied with my answer please vote for me(with at least 3ups) . thanks in advance
Nov 22, 2010 | Nokia 2730 Cell Phone
What is the power supply for the hp 845c printer ? Thanks,
Electrical specifications NOTE: The HP Deskjet automatically accommodates the worldwide range of AC line voltages and frequencies. There is no on/off switch on the power adapter. Category Specification Input voltage 100 to 240 volt ac (VAC) (+/- 10%) Input frequency 50 to 60 Hertz (Hz) (+/- 3 Hz) Power consumption (maximum) 4 watts maximum when off
4 watts minimum when idle
45 watts maximum average printing (Printer carries the ENERGY STAR emblem)
Jul 16, 2010 | HP DeskJet 845c Printer
Cannon i80 printer will not turn on, appears dead
Take the adapter back to the guys at radio shack, they should be able to find what they missed or did wrong the first time.
I suspect the adapter is the power supply and plugs into the wall. That's the item that wouldn't let it turn on, it's either shorted or one of the wires are no longer connected.
The Vanguardian
Aug 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP scanjet 3500c doesn't turns on
Look at your AC Adaptor for your Scanjet and see what the output voltage is. Then try to find another AC adaptor that will fit your scanjet and has the same output voltage as your original. It could be that your adaptor is bad.
Feb 08, 2009 | HP ScanJet 3500C Flatbed Scanner
My xbox 360 is from the united kingdom (england) i am in canada, i have bought a power converter to convert voltage, but, the screen is in black and white!!ive plugged everything in as normal!am i doing...
A UK Xbox will work on a uk TV, which uses the PAL colour system. Canada use NTSC so the image is black and white. Can the Xbox be configured for NTSC ?
Dec 30, 2008 | Microsoft Xbox 360 Console
Power adaptor
If you can find an adapter with the same Connector, Polarity,Voltage. and the required Amperage or higher, it should work.
You might be able to find the exact part on Ebay or an online store.
Here are the part numbers depending on you location.
218864-001 Power module (USA, Canada)
218864-371 Power module (Asia/Pacific)
218864-A71 Power module (PRC)
218864-AB1 Power module (Taiwan)
218864-AC1 Power module (Hong Kong)
Jul 04, 2008 | Compaq S4 100 Flatbed Scanner
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
HP printer AC power adaptor 0950-4399
I want to purchace new HP printer AC power adaptor 0950-4399 from mumbai where shall i contact
Mar 26, 2008 | Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
