Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Computer beeps, won't start up
After switching the positions of my RAM modules, my computer registers several long beeps (I turned it off after 12). Even after switching back the positions of the RAM, it still does not work. I am told this may be a motherboard problem. My motherboard is an Elitegroup 760GX-M model. Could anyone please provide some assistance?
  • 1 more comment
  • erichami Apr 20, 2009
    Thanks rtrahan. I have changed the position of the sticks into every possible configuration and still get the same result. Unfortunately it might be a bigger problem than the position of the RAM.
    Is there a possibility the static may have got into the motherboard and fried it? Just asking... how big of a risk is that?
  • erichami Apr 21, 2009
    The original RAM had been installed on the motherboard since I have had the computer, about four years or so. About two weeks ago I bought the new RAM and installed it. I made the switch yesterday because the new RAM didn't appear to be working.
  • 741 Answers
Nope not a motherboard problem, a RAM problem, the constant beeps give it away...you may have damaged one of the sticks..try with one stick, then the other and see if it works...
Posted on Apr 20, 2009
  • 1 more comment
  • Randall  Trahan
    Randall Trahan Apr 20, 2009
    well don't give up that easy, you'll end up spending hours of time troubleshooting. Get some RAM you know works, and put them in...won't be the first time I've heard of two sticks going out...I've been down this road...now if you put the new RAM in, works for a few minutes, and it beeps again, then something on the motherboard is burning up the RAM..
  • Randall  Trahan
    There is a better possibility that you fried it with static when you moved it...it was working fine before you switched it right? How long was it running on the motherboard before you switched. Normally if a motherboard fries the RAM it is upon start up with a jolt..
  • Randall  Trahan
    Randall Trahan Apr 21, 2009
    One website I use to ensure RAM will be compatible with the motherboard is www.crucial.com. Just let it look at your system and it will tell you exactly the time of RAM you need, ie PC5300 667MHz, PC6400 800MHz, etc..not all RAM is equal and yes it must match your motheboard, that what the crucial site does for you match your RAM to motherboard..good luck..
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
My cpu is making 1long beep and 3 short beep sounds and not restarting.
This POST beep code usually means a RAM problem.
Try reseating your RAM module/s and reboot your computer.
Try the BIOS setting and check the RAM size, does it match the total installed RAM.
If you suspect the RAM is faulty, remove the RAM module/s and take it to your friendly computer repair shop and get them to test the RAM for you.
Jan 20, 2012 | ASUS M2N-MX SE Motherboard
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
I get beeping when I start the computer, and it wont start?
This is called a beep code. It is used for troubleshooting when you are unable to boot your computer. Here is a listing of the Dell beep codes, depending on the sequence of beeps that you are hearing, you will find the problem listed here. How many beeps are you getting and what model of Dell do you have?
1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
http://www.bioscentral.com/postcodes/dellbios.htm 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Oct 18, 2010 | Dell Dimension 3000 PC Desktop
I have a HP Pavilion dv6700 special/limited edition. I start it up, and all lights turn on and i can hear the computer is on. But the screen is black. And then I hear a beeping sound three times. First one...
Sounds like you have a memory problem. Either a RAM module is defective & needs to be replaced, or the slot where the RAM module goes into is not making good contact between the motherboard & the memory module, & needs to be cleaned.
Try first cleaning the RAM module slot with a non-oily contact cleaner. Leave it to dry for few minutes then install the RAM module & test if the computer will turn on. If it does not, replace the RAM module with a working one & test again.
Sep 09, 2010 | HP Pavilion DV6700Z Notebook
Computer wont turn on... asus p4s800 mother board
The 3-beep code (probably 1 long then 2 short beeps) means a memory problem. Take the RAM modules out of their sockets, gently clean off their contact fingers with a pencil eraser, and plug them back in. Make sure they're firmly seated and latch into place. Try restarting the computer.
If you still have the beep code, try to borrow a known good RAM module of the same type for testing. It doesn't need to be the same size (in MB), but close in speed. This will let you determine if the motherboard itself is bad.
If you don't have a known good module for testing and there's more than one module installed, take them out again. Reinstall one and try restarting the computer, and repeat for each module. This allows you to check each one separately to determine which is causing the problem. (This is where a good piece for testing is handy. I've been stung several times by all the memory being bad, and thinking it was the motherboard. Now I always keep some good memory for testing.)
Good luck, and thanks for using Fixya.
Mar 07, 2010 | ASUS P4S800-MX Motherboard
When starting up the computer, I get 5 short beeps then continous
These beeps seem to show that your system did not detect any RAM (memory) modules connected to it. Please check.
  1. Open the CPU case (turn the PC off first)
  2. Remove the RAMs from the slot.
  3. Turn ON your computer without the RAMs installed. Then observe if it gives the same beeps. If it is the same, then the RAMs might fail to register.
  4. Try to plug in carefully the RAMs in place. If you have 2 RAM modules, try to test 1 RAM at a time to see if the combination of the 2 mess up your system.
Feb 13, 2010 | Computers & Internet
Computer Wont respond after the RAM was switched. 6 beeps.
Hello
The beep code you are getting is faulty ram. There really is not anything you can do to fix this yourself. Sorry
Best regards
Andrea
Nov 05, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
Complete failure after modifying RAM
If you know how to remove the cmos battery, I would suggest that you do so. Leave it out for 20 secs. Restore the battery (if possible use a battery tester to verify the charge in the battery). Restart the computer and press whatever key (delete, F2, Esc) to get into your setup to see what the system setup is reading. If you know how to change the settings for your changes then proceed.
Jan 21, 2009 | Computers & Internet
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
575 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
