Philips GOGEAR SA6045 MP3 Player Logo
Posted on Apr 20, 2009
Unit says please format the player with your pc
It had been working fine
  • daycarepro Apr 20, 2009
    It had been working fine and the pc is not recognizing the mp3 plugged in
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1249
Points
12
I get this regular i find restarting computer with the device attatched through usb works
I have a WD media player and my HD crashed recently. I installed a new one but i now get an error message saying that my HD is not detected yet it works fine on the PC - please assist.
If it works OK on you PC and not in the WD, it suggests to me that you have the disk incorrectly formatted. Most media players use a Linux format not a windows format (fat or ntfs). Try deleting the partition in the PC and then format it with the WD. I presume that you replaced it with the same size disk as many of them will not use anything larger than the original size.
2helpful
my mp4 lo prendi y me sale please format the player with your pc y no lo puedo apagar q puedo hacer
3helpful
My yp-k5 is not working.........the screen buttons itself is disabled..wen switched on.....i get a message.to delete 20 mb files......how can i do that wen d buttons itself r not working.....i tried...
First off, make sure the unit is not on hold. You can check that by looking at the side for the HOLD switch.
Next try to reset the player. Here's how you do it:
With the unit, get a paperclip and poke the reset hole at the back of the unit until the unit shuts off.
Try to turn on the unit and check if the buttons will be activated. If they'll work, format the player.
Next, what exactly happens when you try formatting the player using your PC?
You can try going to My Computer. There, you're going to see teh YP-K5. You DO NOT format that. Rather, double click on it. You're suppsoed to see a STORAGE folder. Right click on that directory and select FORMAT.
Hope this helps!
xo
R
1helpful
Mp3 player says boot error please format
i just downlouded a few songs went to see iff it worked . Now it says boot error please format unit
7helpful
8answers
Boot Error please format unit
my rca mp3 player started saying boot error please format unit how do i fix this so i can hear my music again
2answers
Boot error! please format unit
It might be cause by a corrupt firmware. You need to have a utility that restore the mp3 player to its original setting. i had exactly the same problem with my ipod shuffle 1st generation 2 years ago. Good thing Apple has that utility for me to download and until no it is still working. Try to visit and upgrade the firmware using this link for you mp3 player http://support.rcaaudiovideo.com/downloads.aspx?product=192
Please Rate Appropriately Thanks!
1helpful
Philips DA1102 DAB+MP3 Portable Player
USE REAL PLAYER TO TRANSFER TRACKS TO YOUR DEVICE
MAKE SURE MP3 FORMAT
SYNCRONISING WORKED FOR ME
Loading circle constantly onscreen
Try formatting, synch your library using a synch software like media player, realplayer, media monkey etc. Do not remove the USB if it is 'Updating'.
1helpful
2answers
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
2answers
"Format Error" after format with windows explorer (XP)
Hello, please check this link: http://support.sony-europe.com/DNA/WM/NW... If you need more info please advice. Arpi
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
