Question about SmartDisk FireLite XPress USBFLXP60 60 GB USB 2.0 Hard Drive
Computer not reading H.D. - H.D. seems to be working at usual just not responding with comp.
My Computer is not reading my hard drive but you can hear and see the hard drive light up and running but my computer does not seem to pop up that it is connected. Please help! p.s. the day before i accidentially pulled out the firewire cable thinking i had already ejected the h.d. so this might be the cause but what is the solution to fixing this? Thanks
  • Longtime User Sep 24, 2017
    Hi Banshee1, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Are you trying to boot from this drive?
    Does the drive contain data that you don't want to lose?
    Is it an external drive or build into the computer? Is it HDD or SDD? Is there other information you can tell us that may help with options, like computer operating system, brand of disk, how old it is?
    If you have data on the disk but the computer cannot read it, one option may be to send it to a data recovery place. If you don't care about the data then you could just reformat it and start again.
SOURCE:
  • 158 Answers
SOURCE: Dropped SmartDisk
email me on [email protected] and i'll see what I can do
Posted on Aug 14, 2007
fwadley
  • 482 Answers
SOURCE: Firelite 60 GB Hard drive
Hard drive has went bad on you. Get a new one.
Posted on Nov 26, 2007
  • 4234 Answers
Depending upon how hard the jar was to the internal mechanism, the data may be salvageable. I would guess that the first problem is broken connections at the USB connector. This case is just snapped together with a laptop drive in it. Carefully open it up and look for anything broken.
Worse case scenerio, you can get an adapter to plug the drive into a standard IDE cable inside your tower system.
Dan
Posted on Mar 20, 2008
Damilare
  • 358 Answers
SOURCE: My computer does not acknowledge my hard drive.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
Posted on Nov 21, 2009
  • 186 Answers
SOURCE: how to use ?? with Mac I don't seam to have
go to the start menu select my computer. then plug in the device if the device does not pop up you are not getting a connection. check the device to see if the part that goes in the usb port is not loose or have any malfunctions. if you open my computer and you see it when you plug it in double click the port its in to open
Posted on Jan 31, 2011
I have a western digital essential 1 TB external hard drive.I have windows vista and it has usually worked fine until one day i tried to plug it into a different computer that has window's 7, but it...
Doesn't sound good!
Either the hard drive itself or the drive controller seems to be faulty. The first step I would take would be to dismantle the hard drive enclosure and fit the drive directly into a PC or purchase another external hard drive enclosure and try it in that - you can find enclosures cheaply on ebay. Ensure you buy the correct type i.e. ATA or SATA.
If that does not work then you may have to resort to a specialist to recover your data - a google search on 'hard drive recovery' will give you some options.
Jan 25, 2011 | Western Digital My Book Essential 1TB...
250gb external by coolmax, not showing up on comp
The unit (more precisely the hard disk inside it) just died - nothing you can fix unfortunately.
Jan 07, 2010 | Computers & Internet
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
How do I move a file from one computer to another
The mac computer should be able to read your Windows partition, but be warned that it will not work the other way around. There are many ways of moving the file, such as copying to a flash drive and plugging the flash drive into the Mac computer, or e-mailing the file to yourself.
Mar 03, 2009 | SanDisk Open Box 1GB Cruzer Mini...
A disk read error occurred. the comp. said press ctrl+alt+del
The computer cannot find the operating system, the disk error message means it cannot find the hard disk, you most likely have a faulty hard disk or less likely a faulty disk controller.
You can test the hard disk by removing it and connecting it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer cannot detect this drive as an external drive then you will know your hard drive is faulty ad you need to buy a new one and install Windows and programs etc..
Jan 25, 2009 | Dell Latitude C400 Notebook
My HP pavillion laptops keyboard is non responsive. The computer works, mouse works, but the keys wont respond. It seems to be locked on numslock the liht stays on but it doesnt respond to any keys. I dont...
i had the same prob with my sony vaio..but soon found the way out all by myself. first, run a thorough antivirus check and then reboot your comp. then reinstall your keyboard drivers. reboot your comp your comp again. your keyboard will be working. trust me..
Dec 13, 2008 | HP Internet Keyboard
No boot disk error when hard drive disconnected
Are you making the disk the "master" device when you plug it in to the PC?
Nov 02, 2008 | Computers & Internet
Computer hard drive?
Hi your problem sounds more like a virus or something similar before you buy new hard drive try downloading spybot search and destroy.
When i had similar problems on friends comp using spybot solved the problem it is a free virus and spyware remover programme just type in a search engine spybot search and destroy
then download it then run it it will then scan everything on your hard drive and this should then list all viruses and spyware and allow you to remove them give it a try let me know how you get on.
As for the price of new hd it all depends on the size speed etc but could cost from $80 upto $250 you can spend a lot of money depending on size of mem hope this is some help to you
Feb 25, 2008 | Computers & Internet
She won't run
do you still have your restore CD? try to fresh restore it and updates everything on that unit again. Often online gamers send you malicious script that crashes your system.
Aug 04, 2007 | Gateway GT4022 PC Desktop
Hard Drive not responding
The clicking sound you hear is unfortunately the death rattle of a hard drive. The sound is a regular click, click, click. This is because the heads of the drive can no longer find or read the sync track on the drive and usually means all the data on the drive is unrecoverable by external means. Hard drive labs can recover data from these disk failures but it requires them to dismantle the drive and that is usually a very expensive upwards of several hunderd dollars depending upon the amount of data recovered. You can purchase a replacement drive for the case and install it yourself if youare brave enough, for less than the cost of the complete package if you are good with a screwdriver.
Jun 27, 2007 | Trekstor DataStation maxi y.uh 400 GB USB...
SmartDisk FireLite XPress USBFLXP60 60 GB USB 2.0 Hard Drive Logo
75 people viewed this question
Top SmartDisk Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
