My Yamaha MD 8 track recorder displayes Error 8 and will not eject the disk.
My yamaha MD 8 track recorder will not eject the MD disk. Error 8 is displayed.
robotek
  • 1512 Answers
SOURCE: sync clock with yamaha RX-V659
Hi eventwave
Are you using the 48khz or 44.1 for you spdif output. check that you have the output correctly formatted or it will not sync correctly. You should not need to have clocks synced to get spdif to work.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 06, 2008
SOURCE: Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Posted on Feb 03, 2009
SOURCE: av amplifier
The display problem is because the solderings on the back of the display are broken. To fix it you have to open the amp and redo the solderings (there are about 50 or 60 of them). There is a Youtube video that shows how to do it. I have fixed this on my DSP-A1.
I also have the problem with the motorized volume control. I have tried cleaning it, and it works for a few days, then it's stuck again. I guess I will have to replace it to have it fixed permanently. The part number is VZ621400, a new one costs about 40$.
Posted on Jun 23, 2009
  • 127 Answers
SOURCE: Yamaha front panel display dim
You can change the LCD brightness in the Setup / Display menu.
Posted on Mar 02, 2010
  • 127 Answers
SOURCE: have hdcp error flashing on front display
HDCP is copyright protection for HDMI ensuring that you can't copy the protected material.
Did you connect some new DVD player or new TV to the receiver? However the error should clear once you disconnect everything from HDMI. If not, try to restore the receiver to factory defaults.
Yamaha CDS700- on some cd's reads the disc but struggles playing first track. Have to eject and close and play again. Other discs fine
If the cd plays fine on other machines then your machine has laser focusing issues. Cd may also be defective. Or it could be that the disk is just not compatible with your Yamaha. Happens.
Oct 09, 2016 | Yamaha Audio Players & Recorders
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Yamaha MD4 mini disc recorder error code 02
Many unit that have a less than professional MD mechanism need lubrication and freeing up the mechanism by use and applying grease where it is needed. There is no incentive for the company to use good lubrication as they won't sell you a new unit down the line not to mention these mechanisms were not designed to last 20 years- some of them barely make it 1 year.
Jun 20, 2012 | Audio Players & Recorders
Md4 recorder mini disc. will only power up error 04
I have also the same problem with my MD8 recorder, the same error code: ERROR 04... From the yamaha website it says,
Error 04: The magnetic head didn't raise off of the disk.
Apr 09, 2009 | Audio Players & Recorders
Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Mar 16, 2009 | Sony MDS-JE440 Mini Disc Player
Yamaha AW16G
Maybe you could pull the hard drive out and mount it inside a computer, and format it that way.
Mar 25, 2017 | Electronics - Others
Recording favourite tracks
After bookmarking the selected tracks and you are ready to copy them to the HDD, make sure the bookmark abbreviation is lit up in the display. All you have to do is press the bookmark button on the remote or on the recorder- after pressing "copy" but before pressing play.
May 15, 2008 | Yamaha CDR-HD1300 CD Recorder
172 people viewed this question
 Grubhead
Grubhead
