Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain or stat new cycle, no error message
The washer makes noise, but it won't drain or start a new cycle. It finally says cycle complete, but it won't unlock the door. When I get the door unlocked the clothes are still wet. It doesn't show any error messages.
  • jpreciousmet Apr 20, 2009
    I know this sounds funny, but looking at other solutions this site, we solved our own problem. Like others, it was a clogged pump filter. We removed 3 screws from front bottom, remove cover, and unthreaded the filter. It was full of lint, toothpicks and pen cap. Now all is right with America! Well, anyway at least the washer works. Thank you!!!
  • 6,784 Answers
HI, this is a defective CCU(Central Control Unit). you must have it replaced asap. this will correct the error.
Posted on Jul 27, 2009
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
When tub drains beeps twice and won't continue
Hi - Does the drain pump make a humming noise as well? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
184 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
