Question about Brother MFC-440CN InkJet Printer
Paper jam message
I have tried EVERYTHING to get rid of this message. There is no paper jam, yet it will not go away. HELP!!!!!
  • 1 more comment
  • Anonymous May 10, 2008
    i have a paper jam message when there is no paper jammed in the machine this is my second mfc 440cn machine which continues to read paper jam and there is no paper jammed in the machine
  • Linda Irving May 12, 2008
    Paper jam message on all the time, no paper left in machine where jam was, also getting Error code 32 unable to print.
  • Anonymous Mar 12, 2014
    replaced the fuser unit and now there is a message that says jam inside and there is not any paper jammed
  • 832 Answers
Richie, I ve had the same message and was wondering why: You have to open the printer.You will find rest of paper near the left side gear wheels(where powercord is pluged in) which cant be seen from outside. Another point is that the encoder strip (foil paralell to printhead belt) might be out of position. The jammed paper hamight had pushed the encoder out of position. the encoder strip has to be fixed upon the printhead.
Posted on Sep 21, 2007
I am also getting the "printer jam clear paper path" message
Check paper sensors in the paper path may one of them the shutter is stack.Ensure that the are free and in position.
Aug 22, 2009 | HP LaserJet 3015 All-In-One Printer
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
HP 5510 OfficeJet - error message "Remove & check color cart"
check all areas for any paper jam, also check the feed roller in the paper trays if the roller are slick with paper dust, clean them and then reinstall the paper. Sounds like a paper sensor is not been cleared. then the error message, should go away on reboot.
Mar 16, 2009 | HP Compaq Evo Notebook N600c
Paper Jam Error 381
Most of the time the jam will be behind the printer. Open up the back door and see if you see any paper stuck in on the roller. Also remove the printer cartridge by pulling on the piece sticking out. Easily slides back in, so no sweat on that part. Let me know if you have already tried these methods.
If that doesn't work. Unhook the Data cable on the back of the printer, shut the printer off, and unplug the power cable from printer. Wait about 3 minutes and plug everything back in and turn back on the power switch. This should erase the queued errors.
Apr 19, 2008 | OKI C5500n Printer
Paper wont feed then says paper jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect)
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Brother MFC-440CN InkJet Printer Logo
225 people viewed this question
James Cagle
James Cagle
Jim Keysor
