Question about Acer Aspire 5100 Notebook
Acer Laptop with Vista and accessing a wireless network
Vista and the Acer laptop see the wireless access point; Net Stumbler sees the access point; my Dell with XP Pro connects to the access point; my other laptops with XP Pro and Home automatically connect to the access point. I have an "open" connection to the AP. When I boot up Vista it sees the access point but won't connect. Any help is greatly appreciated!
    Problem Solver:
Ok i found a problem like this with my acer lap top that had home basic, if you have the green tab at the top of the screen called " acer emporing tecnology go on that the pic of the world and try to find a solution in there! have fun and good luck
Posted on Sep 21, 2007
SOURCE:
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
Had to do system restore, now it says to undo changes, cannot enable broadcom radiio on acer wireless laptop
Connect to the internet by connecting a Ethernet Cable to the Laptop and the Wireless Access Point/router. Open the Device Manager, Network Adapters, Click on the wireless adapter, is it enabled? yes or no? Yes, update driver. reboot laptop. Is your Wireless Access Point securied? unplug the wireless access point , wait for 30 seconds or so, plug in, wait for selftest, reboot laptop. You didn't supply the Laptop Make, Model or the OS you are using?
Jan 15, 2013 | Computers & Internet
I have a netgear n150 hooked up to my gateway laptop running windows 7, my gateway laptop running windows xp allows an internet connection but my gateway laptop running vista will not allow a wireless...
There might be a problem w/ your IP address or DNS server, try to open LOCAL AREA NETWORK CONNECTION STATUS in your laptop running xp, click support/details, Then copy the DNS server address and alternative dns server address.
open your vista go to Network Connection/LAN properties, then double click Internet Protocol (TCP/IP, mark obtain ip address automatically, then the lower side Mark USE THE FOLLOWING SEVER ADDRESS then paste the dns server address which you copied from xp laptop. same w/ alternate dns server, and then click OK. DONE.
JUST TRY IF ITS HELP FULL.
Jan 15, 2011 | NetGear WIRELESS-N 150 ACCESS POINT WRLS...
Wirless network - laptop
See what ip,gateway and DNS its getting from the access point.If its getting the right ips then your network should work. If it is not getting the right ips then there must be some problem in the DHCP configuration of the access point
Jun 25, 2009 | NetGear WGT624 Wireless Router
DWL 520 D Link Wireless PCI
disable the firewall and check the configuration of the ap
Dec 02, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Acer aspire will not connect to wireless network
Does your home router have a password? The only thing I can think of doing is removing all the preferred access points from your wireless card's utility or windows (located at start => Setting => Net connections => Wireless => Wireless Networks.
Then add your home access point back.
Aug 20, 2008 | Computers & Internet
XP and Vista wireless LAN - computers don't see eachother
Here is an article that should help -- there may be a issue. based on this article the Vista Computer is connected to the internet or ISP's network with a wire.
Ad-hoc networking access point
Dec 17, 2007 | Computers & Internet
Connecting to internet
vista you click the windows logo at the bottom left and select "connect to", XP click start, my computer, network places, view network connections, select a network by right clicking and connect
Nov 11, 2007 | Computers & Internet
Trednet Access Point keeps dropping Network connection
Trednets are know to do this if you have another wireless component close or next to the device. Do you have any 2.4ghz phones? Cell phones? Other wireless devices? If you have not tried yet, Try switching the channel on the access point. If its not a channel issue, try getting new firmware and test the signal strenth with a wireless sniffer such as Net Stumbler
Jun 14, 2007 | Trendware TEW-450APB (TEW450APB) 802.11b/g...
Acer Aspire 5100 Notebook Logo
101 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
