Question about Mitsubishi CS-35505 35" TV
White horizontal line down middle of TV screen
I have a horizontal 3 inch white line that is present when I turn off the satellite box or when I am turning the channels. The background color is usually black but when the line is there, the background color turns to a bright green color. It comes and goes. When it is present, I have degration of the TV picture. Had TV repair guy look at set and doesn't know what it was.... Could you please help......
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Posted on Sep 21, 2007
SOURCE:
Samsung ln55a950. There are black horizontal lines that start of strongest on the very right of the screen and fade to gone at about the middle. The lines are maybe 3 pixels tall before fading, but they...
I have similar issues with my Samsung TV model LN55A950... all I did was take the back cover off...unplugged the two wide ribbon cables of the panel from the T-Con board, then turned it on...I waited for a minute until everything normalized. at first, all i see were similar lines...horizontal pin stripes on white background...white background because the panel is not connected to any image source. Then all lines are gone, after the 'normalization." you should only see white all through out. I then turned the unit off...connected the two cables back, turned it back on...voila! my TV is back to normal viewing, no more lines!!!
Jul 06, 2011 | Samsung LN55A950 55 in. LCD TV
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
Mar 10, 2008 | Philips 32PT6441/37 32" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Horizontal line in the middle of the television
From your description of the problem, there seems to be a Cold solder in the Vertical Oscillator or Deflection Coil circuits.
If you know Solid State electronics, and are good with a soldering Iron, sure u can do this yourself.
U gotta trace the Vertical section components and locate the cold solder. In most cases it will be a loose connector from the Deflection coil to the main PCB.Also check for the soldering of the Vertical output IC.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
White Screen w/ White Lines, Sound On, Turns off after 2 or 3 secs.
Hi If you mean thin white lines, this is is an indication of a problem in the Horizontal Drive ckt. most likely the Damper Diode has opened or shorted, this would cause the visual symptom and then the set would shut down, unfortunately this is a problem best left to a qualified technician to repair, hope this helps.
Apr 12, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
328 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
