Question about Numatic Henry Bagged Canister Vacuum
Rewiring a Henry Hoover
I want to rewire my Henry hoover to blow instead of ****, I'm assuming swapping the wires around will just make the motor turn backwards, blowing air out the hose. I can't find any circuit schematics on the web though, so I don't want to connect it and blow any components I wasn't expecting to be in there. Anyone have a circuit diagram or done this before?
    New Friend:
No it wont work it wont make any difference , the field coil connections have to be altered , suggest buy a george it has a place to screw the pipe on to blow
Posted on Jan 29, 2013
Henry hoover doesnt require a bag!
Posted on Jun 04, 2012
    President:
  • 389 Answers
Ignoring for the moment the fascinating question of why you would actually want to do this...  I'm sorry to tell you it won't work. Swapping the wires over will make no difference.
Posted on Apr 20, 2009
Henry hoover hi low switch
wtf you dont the wires are hard wired to the motor
Mar 15, 2014 | Numatic Henry Bagged Canister Vacuum
No power, electrical wirring is intact from power plug to switch to pcb
normally with a henry the cable breaks from where it joins the hoover just take apart from hoover end cut about a foot of cable off and then rewire
Feb 09, 2014 | Henry Numatic "" Canister Vacuum
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
Water in Henry vacuum cleaner motor.
I would say it's essential to open Henry up, otherwise (assuming he has indeed got water inside him) you will wait for ever for him to dry. He can be opened very easily - just undo the four recessed screws on the underside of his hat, and the upper part will lift off. Pay attention to the switch (or switches, depending on the model) as that may be more vulnerable to water penetration than the motor. The motor compartment may have water in it, but the motor itself is probably fairly well protected. When you've got it opened and mopped up any visible water, it will help to give it a blow with a hair dryer.
If in doubt, though, get a professional to deal with it. It pays not to mess with electricity if you're unsure!
Jan 06, 2010 | Numatic Henry Bagged Canister Vacuum
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Henry Hoover throwing trip switch in house
Sounds more likely to be the switch than the motor, especially if it is the model with the top switch rather than the side "rocker" switch. If you are in the UK, speak to the technical people at www.a1cleaningsupplies.co.uk they can post a replacement. Otherwise outside or even within the UK you can contact the manufacturers technical people. Website is www.numatic.com
May 25, 2009 | Numatic Henry Bagged Canister Vacuum
Hoover Savvy Model U8181-900 Rewiring
The brush roll motor is most likely what caused the problem to the circuit board. You would look at about $100 or so for the 2 parts.
Jan 16, 2008 | Vacuums
Replacement motor
The manual only show one wire from the motor going to the switch, the other going to the cord, then the ground wire. I would wire it the way your old motor was, could be that some models maybe were 2 speed and the other wire would be used for that. Either that or the wrong motor was in the box, it is the right part number (43576197 is Hoover number)
Nov 15, 2007 | Vacuums
Numatic Henry Bagged Canister Vacuum Logo
1,927 people viewed this question
Top Numatic Vacuums Experts
Chris Nomland
Chris Nomland
Andrew Taylor
Andrew Taylor
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
