Question about IBM ThinkPad X41 Tablet PC
After pressing access imb the following error come up 0271,0187,091 I've went into default setting and the same problems acord what can i do to resolve the problems? ibm thinkpad x41
My name is frank and i have this problem with my IBM thinkpad T40
which is every time i boot the laptop then Error 0271 appears what should i do to prevent this error thanks
Posted on Jul 07, 2009
My google voice search is not working! how do i fix that problem????
First tap on voice search option. Press on your manu button (or default start key) tap on setting > tap on phone search select your apps as u choice. Thanks
Feb 02, 2015 | Tablets & eReaders
Sony xperia troubleshooting
I don't knwo if your problem is troubleshooting or 404error
1-solution for troubleshooting:
No plug-ins are found
  • For some phone types and in some countries, there might not be any plug-ins for the LiveView application.
Your LiveView micro display is automatically turned off
  • The battery level is too low. Charge your LiveView micro display.
  • Pairing failed. Enter pairing mode again.
Unexpected behaviour
To reset your LiveView micro display:
  1. Make sure that your LiveView micro display is turned off.
  2. Press and hold the Power key for approximately 8 seconds until your LiveView micro display is turned off again.
The phone media player cannot be controlled from LiveView
  • LiveView supports the standard Android media player. If your phone manufacturer has removed the standard Android media player, LiveView will not be able to control it.
2-solution for 404error :
A/
clearing the PROXY in the APN settings. If you're on ICS, do the following. Open the Settings > More... > Mobile Networks > Access Point Names > [Your APN Name] > Proxy - clear this field.
OR
B/System Settings > "More..." in Wireless and Networks > Mobile Networks > Access Point Names (APNs) >press the menu button, inside the menu press "Reset to default" > now another option will appear called "Internet 3G" (modem) , besides the "Portal 3G". Choose the new option "Internet 3G" and you are done!
Good Luck
Jul 04, 2014 | Tablets & eReaders
I have a new tablet, charged and protected but when I was changing contrast settings it went black and I cant get the screen to come back on past startup
Sorry about this.
Well, seeing it is a new tablet, either of two things can be done.
Your tab is booting beyond Startup but you ain't seeing it because of the contrast/black screen setting.
To confirm; step into a dark room/space and hold a flashlight very close to the screen, you'd see your tab is at its home screen already.
Anyway, you will have to default factory reset it as it is or you could attempt to navigate (while in the dark room/space and using/holding the flashlight) Swipe to open/unlock it----Settings----display and brighteness-----brightness----'move cursor up to increase brightness'. Done.
Second option with dark room/space is tedious and strenuous.
Factory/hard reset is an easy option to try.
At the same time, hold/press both the volume up key/button and the power button/key.
Follow the system prompt afterwards.
Or
Press/hold down the volume down button/key and the power button.
Follow the system prompt thereafter to factory/hard reset your tab.
Best of luck.
Oct 10, 2017 | Umi PIPO S1 Android 4.1 Dual Core 7 Inch...
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Android tablet keeps getting error when trying to connect to the net. process com.andriod.browser has stopped unexpectedly.
Personally I'd flash it. I think you've got something corrupted in your system and its being triggered when you attempt to access the browser. Alternatively you can try downloading a different browser (http://www.4shared.com/android/ki088UbS/Dolphin_Browser_v200.htm) click download now wait the 20 seconds and an apk will show up for you to install. You will have to set your reader to accept outside downloads its in settings. Yea other than that do a full flash. Go to the support section of the cruz website and you'll be following the process for upgrading the firmware.
good luck
Jan 01, 2012 | Velocity Micro Cruz Reader R103
Master reset htc phone
Hard or master reset
A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset, follow these steps:
  1. Back up all necessary data by copying any files you want to save from your phone to your computer.
  2. From the Start screen, swipe left.
  3. Tap Settings.
  4. Tap about.
  5. Tap reset your phone.
  6. Tap yes.
Hard or master reset using hardware buttons
If the phone is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu. A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset using hardware keys, follow these steps:
  2. With the phone turned off, press and hold the Volume Up and Volume Down keys.
  3. While still pressing the Volume keys, quickly press the Power/Lock key.
  4. When the device displays 'This operation will delete all your personal data, and reset all settings to manufacturer default. Press Vol Down to restore manufacturer default, or press other keys to cancel.', release the Volume keys.
  5. Press the Volume Down key to reset the device.
Dec 08, 2011 | HTC HD Windows Phone 7
What does the key password mean for wifi
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 07, 2011 | Sharper Image Literati Reader 16375680042...
Samsung tablet isn't connecting to 3g network but will connect to WiFi
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
Mar 20, 2011 | Samsung Tablets & eReaders
My dsixl will not get on the internet
The first thing you'll need to do is find out what IP address range you should be using. To do this:
Click the "Start" button in the lower left-hand corner of your computer.
Next, you will need to access the command prompt. To do this:
Windows XP users click "Run."
Windows Vista users click inside the search bar.
Type "cmd" into the box and press Enter.
Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed.
The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The DS and PC must have different IP addresses.
Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Nintendo DS and for your PC.
Click here to go to our Wireless Router Configuration page.
Use the drop-down box on the left to select, if available, your router manufacturer.
Click on your router's model number, if available.
Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection.
You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this on your Nintendo DS or Nintendo DS Lite, please click here.
Check Nintendo's router info for special notes, if available, for your router.
If you try these steps and you get a different Error Code, please review the values that you entered carefully, since an incorrect manual setup will cause another Error Code to appear. If the 52000 Error Code persists, than the problem may be caused by a basic setting in your router such as transmission rate. Please carefully read the instructions below:
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Feb 28, 2011 | Itronix Duo-Touch II Tablet PC
Lenovo x60 wireless problem
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  • Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Feb 29, 2008 | Lenovo ThinkPad X60 Tablet PC
Open Questions:
IBM ThinkPad X41 Tablet PC Logo
607 people viewed this question
Top IBM Tablets & eReaders Experts
Steven Wander
Steven Wander
Matthew Spark
Matthew Spark
Are you an IBM Tablet and eReader Expert? Answer questions, earn points and help others
