Question about Toshiba Satellite A75-S229 Notebook
I have some problem with this satellite a75-s229
I repair a power jack of the laptop and 2 days later this laptop starting to beeping, 3 beeps 4 beeps 3 beeps and i don't know what is the problem thanks for try to help me!
  • cobaltox Sep 21, 2007
    sorry, but you'll got take a preofessional technical request, i'm not sure you help me, and i need some veteran experience
    thanx
  • 71 Answers
Well i'm not sure exactly what the problem is but check this link and you might get a better idea - http://www.computerhope.com/beep.htm#08 - make sure you choose the correct bios for your problem. hope this helps you.
Posted on Sep 21, 2007
SOURCE:
How do I restore my Toshiba Satellite A75 from the partition
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Aug 21, 2012 | Toshiba Satellite A75-S209 PC Notebook
How do I do a complete restore on a Toshiba Satellite A75-S209
your notebook.
Aug 21, 2012 | Toshiba Satellite A75-S209 Notebook
Toshiba laptop beeps 3 times on startup
hi tom2590
usually 3 short beeps is an indication that you have a bad memory module. try reseating the memory module and see if the laptop would run. also if you have 2 ram modules try removing the other one to test. hope this helps
let me know
janc30
Feb 11, 2011 | Toshiba Satellite A75-S229 Notebook
Hello My Toshiba Satellite a75 s229 Notebook Screen is Black and Glass inside screen looks cracked. Laptop fell 3'' ft. off table onto carpeted floor. Laptop powers up fine and I can hear windows start up...
The way to find out if it's just the screen is to connect the laptop to an external monitor. Pay attention to the F keys when you connect the laptop. On most Toshibas, you'll see a small depiction on the F5 key of a laptop next to a monitor. You either have to press that key alone, or hold down the fn key and then press the F5 key and let go to transfer the signal to the external monitor.
If the external monitor shows up good and you can perform all other functions on your laptop while viewing the monitor, you need only replace the laptop LCD. If it does not display correctly, then you're into the next round of troubleshooting.
Hope it works as above.
Good Luck
Jul 29, 2010 | Toshiba Satellite A75-S229 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
How to remove Toshiba A75-S229 keyboard
Here is the site I use when I get stuck with repairing Toshibas Good Luck.
http://www.irisvista.com/tech/laptops/ToshibaA75/satA75_1.htm
Dec 22, 2008 | Toshiba Satellite A75-S229 Notebook
Beeping power adapter
The problem is most likely (85% sure) with the DC Jack itself, that is one of the rarer issues with it. Since it is a 2-state switch, the likelihood of both circuits closing is my guess. And also the cheapest repair. I have been completely through the A75 without a schematic, and have to remember it's quirks in design.
May 15, 2007 | Toshiba Satellite A75-S226 Notebook
Toshiba Satellite A75-S229 Notebook Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
