Question about HP DeskJet 920c InkJet Printer
Paper jam After a paper jam is corrected or print is cancelled, the printer prints unrecognizable characters (2 or 3 lines per page) at the top of the page and prints at least 60-100 pages which is a huge waste of paper and time. What do I need to do to stop this from happening?
  • Anonymous Mar 08, 2008
    I have the same problem. The only fix I have found to date is to cancel the print job, then turn off both the computer and printer and reboot the whole system. This will fix the problem about 50% of the time. My next step will be to download new drives from HP to see if the latest drives fix the problem.
  • 132 Answers
First when you see that first page come out like that...turn the printer off. You will need to re-install the printers drivers. (the CD that came with the printer)
Posted on Sep 21, 2007
Where is the cancel button?
Most printers don't have a cancel button. You get to "cancel" by going into your computer START menu then selecting CONTROL PRINTER then select CANCEL PRINT JOBS. In the future, I found the safest way to avoid accidentally printing more than intended is to always select "Current Page" when ordering a print job.
I hope that helps.
Mar 03, 2015 | Canon PIXMA Office Equipment & Supplies
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
I print to a printer connected to the company network. I started to print a 40-page document, but realized immediately that the document needed one more change, so i cancelled the print job. After making...
the data send from printer was quered up in the machine memory and was corrupted. reset the print jobs from both the computer and copier. off the machine and on it again to reset the machine memory.
Sep 27, 2010 | Office Equipment & Supplies
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
Three flashes Paper jam/Paper
Output Tray is
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
Head not installed
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Fixed a paper jam, printer started to print one line
When the printer jamed and you had to pull out the jam, the data being tranfered for that job got out of sequence. On Deskjets when that happens, you need to go to the print spooler and delete the job it is printing or you will have the same problem evertime.
Mar 06, 2009 | HP DeskJet 895cse InkJet Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
HP DeskJet 920c InkJet Printer Logo
96 people viewed this question
Ben Johnson
