Question about Craftsman Garden
Fuel leaking from primer bulb on crafstman 6.0 mower
Is the primer bulb replaceable on craftsman 6.0 mower
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
  • 10865 Answers
SOURCE: won't stay running
The carbeurator needs to be cleaned and probably rebuilt. Start with a spray carb cleaner by putting 3 or 4 shots in the carb. Run it for a minute then let it sit for two hours and run it again.
Posted on May 07, 2009
  • 376 Answers
SOURCE: Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
Posted on May 24, 2009
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
  • 376 Answers
SOURCE: 7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
Posted on May 31, 2009
I replaced my primer bulb on my craftsman weedeater an am not sure what line goes where on the primer bulb can you help also not the gas leaks out of carb hole where
In regards to which pipe goes where, it's simple. If you pump your primer bulb with the pipes off, one side will suck and the other side will blow. The suction side will link to the outlet on the carb. The blow side will link to the return to tank. The fuel line with the filter on it will link to the inlet pipe on the carb.
May 12, 2016 | Craftsman Garden
Will not prime with primer bulb , can squirt gas in carb and get running then while running you push the primer button it chokes down the engine .
Does it stay running after you squirt fuel in the carb opening? If yes, then there may be a pin hole leak in the hose going from the fuel tank to the primer bulb and it is adding air to your carb.
Thanks
May 01, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
How do you replace primer bulb on model 917.385125 B&S 550 series motor on a Craftsman mower?
the old primer ball is held in place with a round retaining clip remove it just use a sharp screw driver to pry it out then pull out old primer buy new primer and retaining clip put primer in the take a socket that is the same size as ring and that will slip over the primer push the ring in till it seats
Sep 13, 2014 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Craftsman trimmer #358798420- can't remember how to put fuel lines back on the carb & primer bulb.
Is this question for a mower or a trimmer? If for a mower there is only one fuel line. If it is for a trimmer, there are two fuel lines. One goes from the filter in the fuel tank to the carburator primary inlet. The other goes from the primer bulb to the tank and is the return line. GOOD LUCK.
Jul 26, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a Craftsman chainsaw model 358.352160 and had to replace all my fuel hoses and filter. Now I can't get fuel to the carburetor and the primer ball will not pull fuel from the fuel tank.
Sounds like you have the hoses hook up wrong.
The hose from the tank goes to the bottom of the Carb. The line from the top of the Carb goes to the inlet side of the primer bulb (put your finger on one of the ports and push the bulb, if it collapses without returning then thats the inlet side). The outlet side of the bulb should go tank.
Jun 23, 2011 | Craftsman Garden
I have a Craftsman Gold 6.0 mulching mower with a B&S engine on it that has been idle for about 10 years. It was only lightly used before that and I ran the gas tank dry before putting it away. Today...
Sounds like the primer bulb dry rotted from sitting &/or the float is stuck in carb. If gas is indeed leaking from bulb. It will need to be replaced. While it is apart, clean carb inside & out with spray carb cleaner.
Sep 06, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Craftsman 5HP Mower does not start
try changing your primer bulb
May 31, 2009 | Craftsman Garden
May 30, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
803 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
