Question about Kenwood KVT-715DVD Car DVD Player
Loud Bass Test Like Sound when selecting any source execpt stndby
It even does it with the Volume turned to 0. Insert a Disc and you can't hear any music, just that loud noise that sounds like a bass CD. Defective Brain Box?
  • dansXR2 Jun 02, 2009
    Are you serious? I only had the ground to the wiring harness at the headunit, and just velcro pads to the brainbox... I'll try this tomorrow and see if it works then.
I had the same problem make sure you ground the indash unit well and brain and i had to get a ground isolator loop from the car audio place cost 20 bucks and works great
Posted on Jun 01, 2009
My amp turns on good but after a while of too much bass causes a ugly sound too loud what could it be? Can it be repaired?
If you have over driven the amp by playing it real loud with the bass control turned up, it is very possible that you have toasted the output stages of amp.
Every time you boost a tone control by 3 db you have doubled the output power at that frequency. So if you are "coasting" along at a nominal 75 watts, the moment you boost the bass by 3 db the amp has to put out 150 watts at that low frequency.. Go to +6db and now the poor amp has to kick out 300 watts! And so on.
Rule of thumb - you never use your tone controls at very loud levels. Tone controls are there to compensate for the poor frequency response of the human ear at low volume levels - the Fletcher Munsen effect. At low volumes our hearing with the lows and high frequencies so when you play something at low volume you boost up the bass and treble to compensate for poor hearing. At loud volumes our ears respond properly.
Sep 12, 2015 | Car Audio & Video
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
My speakers used to work. They have only been used a few times. The volume settings on my computer are turned up and I have checked all the wires. I have also tried the speakers on two different computers....
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 02, 2011 | Computers & Internet
The receiver is muted when playing in tuner or cd the volume is not coming through the speakers. We can hear it muted when turning up to max its very low. Lost instruction manual can you help. I think my...
I can't find a manual either. Can I assume you really mean the sound is muted for EVERY source, not just tuner and CD?
I'd guess it's either MUTED or a Tape Monitor is active. Turn the volume down, select FM as the source, tune a station and use it as your test source. Look around for indicators that give a clue.
NEVER troubleshoot anything with the volume control turned way up. You'll blow up or damage the speakers and your hearing right after you discover and correct the misplaced control.
Aug 15, 2010 | Nakamichi AV-2 Receiver
I have a problem with my car speaker/tweeter
Sounds like you have the ground and live possibly the other way around from the head unit to the speakers. The reason for you hearing it from both the tweeter and the speaker is that the tweeter is connected in parallel to the speaker.
Swap the wiring and try it.
Mar 21, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
SONY HT-5500D PROTECT IS FLASHING NO SOUND
Protected in short means that the amp is no longer powering the speakers due to one of the following: 1. Volume is up too loud 2. Equipment Failure 3. Dirty power
Turn amp on by pressing the function button on the remote of a source that has nothing on it or is not powered on. If it still says PROTECTED even though you are on a source with no sound coming in, then the equipment is in need of repair. If it simply comes on normal displaying the source turn the volume down till it says MIN. Find the range of your speaker and amp power by selecting a source with music or movie audio and slowly turn it up till either its too loud or says protected. Be sure to double check all speakers and wires to ensure wire integrity as well as proper connection.
Jan 11, 2010 | Sony HT-5500D System
No sound on the internet
You haven't given much to go on here but I'll take a guess. Sounds like you're saying you have no sound from websites when using your browser, but can hear sound from other sources (mp3s, videos, etc. on your computer). Assuming you are using Windows Vista, open your browser (Internet explorer, Firefox, Opera, Chrome...whatever you use to get onto the internet) then right click on the volume icon in the taskbar (on the bottom right of the screen, next to the clock) and select "Open Volume Mixer". This will show you the programs that are running and how loud their volume will play. Find your browser in this list and turn up the volume by moving the little slider below it (up=loud, down=quiet). Hope this helps.
Oct 26, 2009 | Gateway GT5220 PC Desktop
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Kenwood KVT-715DVD Car DVD Player Logo
265 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
