Question about Sony PlayStation 2 (PS2) Console
Unable to play games, cd or dvd.
Seems like disk is not turning. Does the console use a rubber band to turn the wheels?
Same thing happened 2 me buddy i got rockband 4 christmas it would spin but very little so i went and got a new ps2 the slim version now i can play all of the games even ps1 games there the best ur ps2 is just old
Posted on Apr 22, 2009
I have a dvd stuck in the slot. It won't play or eject. I hear the tv trying to eject but nothing happens. How can I fix it?
You will need to open up both dvd case and dvd player! the rubber type band that turns the wheels to open tray is bad, not tight enough to turn wheels! This rubber type band is located at the front of tray. you might be able to get tray to open by taping the top front of player after you push eject, just not hard enough to bend case.
Mar 25, 2016 | Televison & Video
The CD tray wont open on my xbox 360
Do not attempt this fix ur self if your not familar with the dvd drive parts . The problem is the band on the dvd drive motor under the disc tray is slipping . To fix this use a rubber band. Step 1 Remove your dvd drive unscrew all 4 screws , 2 remove green board carefully . 3 unscrew any screw under the disc tray and remove this disc tray , step 4 get a rubber band a small rubber band and replace the band thats slipping put your dvd drive back together and ur good to go . If you do NOT want to do this your self you can go to Solomodsdotcom and they will fix the dvd drive for you . Google search to to replace rubber band on 360 dvd drive . You tube has videos on how to but i wouldnt recommend doing it your self if your not familiar with the parts .
Aug 07, 2010 | Microsoft Xbox 360 Console
Wii Freezing (Band Hero)
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aaa1
Jan 12, 2010 | Nintendo Wii Console
When console starts to read disk; it says open tray
First some basic steps to troubleshooting
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
Try to use several similar Xbox 360-compatible discs in the console to determine whether the disc that you are using is causing the problem. To test whether the problem is caused by a specific disc, use a disc of the same type, such as a game disc, DVD movie, or music CD. If the problem does not occur when you use other discs, that specific disc might be the cause of the problem.
If you suspect that the Xbox 360 device could be causing the problem you can follow these steps
1. If you have access to another Xbox 360 console, try to play the disc on the other console. Or, if the disc is a CD or a DVD, try to play the disc on another device, such as a CD player, a DVD player, or a computer that is equipped to play CDs or DVDs.
2. If you have an Xbox 360 Hard Drive (HDD) or Memory Unit (MU) attached to the console, turn off the console, and remove the HDD and any attached MU. Then, turn on your console, and try the disc again. If this seems to resolve the problem, turn off your console, reattach the HDD and MU, and then delete any saved games for the game that is causing problems.
If this does not resolve the problem but removing the hard disk does, clear the hard disk drive cache
To clear the cache, follow these steps:
1. Move to the System Settings section of the Xbox 360 dashboard.
2. Select Memory.
Highlight a storage device.Do not press the A button, Press the Y button to view the Device Options screen, Select Clear System Cache, and then select Yes to clear the cache.
I presume you do not have a hacked version of Xbox 360 because this problem is prevalent with Xbox 360 dvd drives which are hacked.
if the above steps do not resolve your issue, please send your Xbox 360 to Repairs, call up MS support and check for the charges of Repairs in case your Xbox is not covered under warranty.
Please do rate my solution, Wish you Happy New Year and Happy Gaming
Regards
KreativeGeek
Dec 25, 2009 | Microsoft Xbox 360 Console
My ps2 is broken. It dosen't play games it only plays movies. If anyone cn help me I would be happy to here from them.
Ps2's and Ps3's have separate readers for Dvd/Cd and games. Your game disk reader is likely broken or covered with something that prevents it from reading. Or, your "legal game reader" is broken and can't read the Ps2 certified bands on the disk. Yes, such a device exists to prevent copying and selling games.
Sep 17, 2009 | Sony PlayStation 2 (PS2) Console
CD Rom drawers do not open or close, drive belts have popped out
Unfortunatly, these belts are not availible for consumer purchase and, most service centers will just replace the entire device. i have used regular rubber bands that are identical in size to run many rom drives. this method seems to work just fine.
Its very unfortunate when these original belts break and, there is no replacment belt on the market. the only option is to purchae a store bought rubber band that matches the same size as the broken original band. this will work.
Jun 10, 2009 | Dell Dimension 8400 PC Desktop
Disk reading error
this is a possible laser read problem.
Try an official DVD Movie. And also a music CD.
if it reads nothing at all, i,d suggest a laser head cleaner.
Or a replacement DVD Drive.
Mike @ compurepair.
Mar 26, 2009 | Microsoft Xbox 360 Console
Ps 3 problems with game play madden 08 franchise mode
This sounds like you might have a dirty lens. clean your ps3's lens with any CD/DVD cleaner kit and then try to play the game again.
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
119 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
