Question about RCA HD52W59 HDTV Projection Television
The sound cuts in and out (only on channel 2)
Just enough to miss a word here and there.
It is fed by cabel straight in and no other set has this problem.
Tryed rescan under "set up"
  • 2 more comments
  • stanc2 Apr 20, 2009
    The model is R52WH77
    I have cabel direct into analog coaxel feed.
    R52WH77YX58 is the service model number
    Was that a good number?
    Thanks
  • RCA Master
  • 19,396 Answers
Check if the problem is only on cable or also on DVDs, by connecting an additional DVD to tv to test it.
If problem is only on cable on ly , then it is either the connection cable or the cable box.
If you get same problem on all inputs (eg dvd) then the problem is a broken solder joint to speakers, or a bad signal board (273415).
You find all parts for your set here.
Posted on Apr 20, 2009
  • 87 Answers
If you are sure it is the tv the didital main board is the problem it has the analog tuner on it. some have a digital tuner on top board if you don't have experence call a service center. There are 20 different models for the tv. I need the full model number to get part information.example is HD52W59YX38.
  • Terry Riegel Apr 20, 2009
    Use this circuit if bar code is marked with as22-710 part number 273415. 10 different versions of this model example has to have yx56 or something like that after the number you gave me, on tag next to ser #. should say service model number.
    YES STILL APPLIES TO YOUR MODEL MAY HAVE TROUBLE FINDING PART I CAN CHECK MY STOCK. TAKE A FEW HOURS.
I can hear my xbox but can't see the screen
first off make sure that the chanel is set to the right input. check all your input chanels and make sure that its not on a diferent channel. also check both chanels 03 and 04 if you have an older model.
if all that is not doing anything then there mite be an issue with the av cabels see if any of them are missing the silver cover to go over the pin. if not then the cabels mite be cut inside it befor you go out and by new one try it out on a different tv and with a different xbox to see if theres anything. if the problem persists then i sugjest getn a new av cable for the xbox 360
Jan 05, 2010 | Microsoft Xbox 360 Console
I have just bought a Technics SH 8046 computer graphic equalizer WITHOUT an instruction manual,HOW DO I PROGRAMME IT!
Darren Kelly-themasterofthrowdown...I've had mine since they came out in 1985. Here's what you do...Each of the 4 channels on the upper right function as an individual equalizer. You set each channel one at a time. So, you have the ability to change channels on your e.q. without resetting your faders(you just push ch. 1 2 3 or 4) and the sound of the music will change according to how you set ch 1 2 3 or 4)DON'T UNPLUG THE SH-8046 WHILE THE MUSIC IS PLAYING OR YOU WILL LOSE YOUR CHANNEL SETTINGS -ALL YOU BLUE LINES WILL END UP STRAIGHT ACROSS AND YOU'LL HAVE TO RESET THE 4 PROGRAMS (AGAIN) you don't have to set all of them*--Now, you set them with your finger (sweeping it up and down on the touch-screen (REMEMBER TO PUSH THE (LOCK) BUTTON FIRST)you have to unlockit it...then you have the ability to adjust you frequencies(the blue lines)once you have a good sound, YOU PUSH A NUMBER...say, 1...then push MEMORY then push 1 again...AND CHANNEL 1 will be set ---do the same thing for the other channels --IF YOU PUSH THE L or R button you can set the E.Q. channels different from each other (if desired --it's just an extra function...and both settings will appear on the screen. But I just keep mine both the same(Left and Right). When you record music(like I do - being a Musician) it is important to be able to listen to the play-back-SO YOU HAVE TO PLUG THE CD RECORDER BACK IN TO (PLAYBACK ON THE REAR OF THE sh-8046-(PUSH (TAPE) TO LISTEN TO YOUR TAPE RECORDERorCD RECORDER)to hear what you recrding sounds like.PUSH -SOURCE- TO GO BACK TO REGULAR PLAY MODE---If you ever walk in and cut you system on and nothing happens, check to see if on SOURCE or TAPE-(rec eq) on the bottom right is supposed to make the music sound better,push it to cut it on/off when you make tapes/CD's the red light should cut on ...Reverse --flips your EQ settings upside down(not such a useful function)....I guess that's all I can tell you, this is the only EQ I need for my overall system and I haven't bought another one for the mixer. IT HAS NEVER MALFUNCTIONED IN 25 YEARS -- I'M USING IT RIGHT NOW FOR MAKING PROFESSIONAL SOUND QUALITY CD's. SO HAVE FUN! Darren Kelly- themasterofthrowdown@yahoo.com
Aug 24, 2009 | Technics Audio Players & Recorders
Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
Jun 20, 2009 | Vizio VX37L Television
Sound dont work
Your potential problem is that your audio drivers are missing. You may get the drivers from your motherboard CD or motherboard manufacturer's site. But most of the times realtek audio drivers work for most of the system. You may get it from here. http://tinyurl.com/realtekaudio
In the above website, please select the required drivers viz., 2 or 6 or 8 channel drives. If you have just two speakers, two channel is your need. If you have a 5.1 surround or 7.1 surround setup speakers, you may choose 6 or 8 channels respectively. I guess this should solve your problem. And a simple request, please post more technical information about your problem to get more straight answers.
Regards..
NOTE: Choosing a 6 channel driver won't make your stereo (2 channel) speakers sound like 5.1 stereo.
Mar 17, 2009 | Computers & Internet
Fuse at power cord blows
first check your speaker cabels for short circuit and speaker for  short coil .after you confirm there is no shotr of cabel wires by checking with avometer in ohm postion.connect speaker if the problem excit your speaker is guilty - change it with same configuration.about switches put it in low order and chech for sound level and you can go up after that.
Mar 05, 2008 | Krell KAV-300i 2-Channel Amplifier
Very low sound in main left chennel.
disconnect the cabel of left channel from your amp disconnect the cabel of right channel and put it in place of left channel if the problem goen your problem is in left speaker itself (cabel or speaker).if the problem excit the problem will be in amplifier output stage
Jan 28, 2008 | Yamaha DSP-AX1 10-Channel Amplifier
Sound & display problem on toshiba lcd 32hl95
could be that the signal is not strong enough from your cabel company, just give them a call and they can come out and check. let me know if that is it.
Nov 29, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
Powered mixer gain
use good brand contact cleaner from radio shack or other electronics store and apply spray in the slider of defective channel and move each slider up and down many times.by the way check cabels which feed bad channel for a good condition and test these channel with the good cabel of good channel to confirm that the trouble in channel itself.after all if it is hopeless pass the mixer to service center to fix it.
Oct 11, 2007 | Audio Players & Recorders
RCA HD52W59 HDTV Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
