Alarm system is not activated we just bought the house and it keeps beeping off and on how do we stop it?
I just moved in our house and the alarm is not activated but it keeps beeping what can we do to stop to beeping?
  • Dick
    Dick May 11, 2010
    What "PC Desktop" do you have that has an alarm on it?
    Novelist:
  • 90 Answers
I would try and get the owners manual for the alarm system and see what it says about the beeping. It could be that it is just telling you it needs a new battery installed, something like the battery operated smoke detectors do when the battery is low. There are so many alarm systems out there that it is hard to tell what could be causing the beeping. It could have been configured with a audible alert that when the system is tripped by any motion it beeps when off. It is really hard to say without the manual. You can usually find the manuals on line at the manufacturers website. Good Luck, RAC
Posted on Apr 20, 2009
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Intermittent bleeping from alarm
I'm not familiar with accenta plus alarms but if your motion detector is picking you up then your panel is beeping sounds like the motion is programmed incorrectly.
Mar 28, 2014 | Home Security
Honeywell ADEMCO 6150RF keypad sporadic constant beeping
It is trying to indicate a problem with zone 1. check it out.
Jul 25, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
I have a MOD 600 alarm, installed about 9 years ago. Every time I pass a sensor the alarm makes three beeps. How do I stop it?
Hello. This is a normal response to the motions detector while people are active within the home.
The alarm is a semi active mode that is the motions detector will beep, if a door is open there could be active voice alarm or beeping from Central alarm within the home. The same will happen if a window is opened, beep,beep,beep.
In this mode it lets the home owner while in his/her home that the alarm is on and it will let you know when the doors, windows or floor pressure sensor is activated.
There another mode for the alarm system that is if you have pets. It can be activated that only things that are inactive is the motion and pressure sensors. They beep but will not execute the full alarm system.
The there is full alarm system activation where every sensor is operational----full Alarm On....
Now, if you don't like the beeping, then you can turn the alarm system off while you or your husband is in the home. But it will not notify you if the door, window, motion, pressure sensor are activated. I hope this help you. GB....stewbison
Aug 24, 2011 | Kitchen Ranges
I bought a house with a DIGITAL FRONTIER. DFA3400 Hybrid Alarm System but no manual, I do not know how to set the alarm and to put in a code to deactivate the alarm. I need an owners manual.
Key in the 4 digit passwrrd and press "A" button, this will delay for a few minutes for you to leave the house, lock the door before activation.
If you are at home and want to arm the alarm immediately, key in your 4 digit password and press H button and the alarm will arm immediately (except certain zone such as IR, since you do not want to trigger this while moving around inside the house).
To disarm just input the 4 digit password. Please see or download the manual attached for programming new password and other functions.
Feb 10, 2011 | Vacuums
My system keeps on beeping, how long does it need to beep before it stops
it won't stop beeping because it's indicating an alarm. while in alarm mode no chlorine is being produced. you must deal with the alarm.
Aug 22, 2010 | Intex Automatic Salt Water System for ...
GE/ADT DIY system will not accept master code./beeps twice/2 hour
Press the system status button on the top right and the system should announce the error message that is keeping it from accepting the code.
Feb 17, 2010 | GE Security Simon 3 Wireless Home Security...
Jeep Wrangler after market alarm
There is a small toggle switch that you have to find out usually this switch is installed under the dash and when you find it put the car key in the ignition switch and turn it to the ON position and move the toggle switch position until you here a beep, some of the aftermarket alarms bring a push button switch, if this is the case just keep press it until you here the siren beep and does it, this way you are disconnecting the alarm or in another words your alarm is in a valet mode.
Jan 31, 2010 | Vehicle Parts & Accessories
I bought the car with wiper alarm system and remote start. it wont start the vehicle, could it be because of low battery, the alarm its self works fine, arm and disarm
it may need to be programmed.......
-press the "f" button and hols for 12 seconds (ignore the beep at like 4 seconds.)
-press and hold the unlock button for 2 seconds...the remote should beep two times. each feature that is active will have an led light beside it. press the button to activate the feature. if the light is on the feature is on...
hope it helps...
Jan 06, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Alarm beeping
Not sure, but the 1x active may have to do with some time of alert that you may have accidentally set in your calendar or alarm clock. Check your calendar and alarm for active alerts.
Dec 24, 2007 | Kyocera KX2 Cellular Phone
Computers & Internet Logo
359 people viewed this question
David Payne
David Payne
