Question about Power Acoustik PWM-19 4-Band Car Equalizer
Equalizer doesn't turn on
I hooked the equalizer up to the battery and grounded it but do I need to hook up the remote to the head unit? I thought since it's hooked up to the battery it would always be one and I checked the cable hooked up to the battery and it has power going all the way through it.
-Mark
    Sergeant:
    Champion:
  • 341 Answers
Hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Posted on May 12, 2009
Hookin equalizer to tape deck and recever
The equalizer I have seen have Line in, line out, tape in, tape out and that is how you utilize a unit like this. The line IN goes to the receivers tape record out. The line out goes to the receivers Tape play in or monitor, The tape deck hooks to the equalizer. The record or input of the tape deck hooks to the EQ record out, the Tape decks output hooks to the EQ's Tape in connectors. All these are stereo so there are left and right sides which you need to keep consistent. Red on a cable means Right, the white or black on cables mean Left or the top RCA connector on most equipment.
When playing back a tape the tape monitor is turned on with the receiver and left on. The way you record on tape from any source of the receiver is to select that source and it should go to the equalizer. Then the deck should record that source. To play a tape of the deck hooked to the equalizer then just press the tape monitor button on the EQ otherwise the Equalizer will just act as a loop and equalize any signal source that is coming from the receiver and the tape monitor on the receiver should stay on most of the time. Some equalizers have two tape inputs so you would hook another deck to that input and the owners manual of the equalizer should say how to select buttons to transfer tape signals from one to the other. If you master the concept of inputs and output of audio equipment then this hookup becomes another easy thing to do.
Sep 22, 2012 | Sony TC WE435 Stereo Dual Cassette Deck...
Im having problems installing my equallizer i have it hooked up to a amp. do i put the jacks to the 4 inputs or the 2 outsput jacks
Hi, the equalizer input is from the head unit preamp outputs and the equalizer output goes to the input jacks of the amp. There should be only 2 channels in and 2 (or sometimes 4) out of the equalizer. If you need more help, please provide model numbers of the head unit, equalizer, and amplifier and tell me all of the speakers you are trying to hook up.
Mar 26, 2011 | Car Audio & Video
Purchased an alpine 3011 graphic equalizer that has no wiring diagram...cannot hook it up without knowing what wires do what
You are going to need the DIN plugs for the unit, on the back there are two imput jacks. The left jack is for the imput from your head unit, as far as I know, there is no other way for the EQ to accept imput except for the jack. The right one is for a digital time delay unit (rare). Coming out of the unit there are two output jacks, one is line out front, the other is line out rear. With these, there are also your power, ground, remote power, and speaker out puts. Good luck. I had one of these back in the 80's.
Nov 13, 2010 | Alpine Car Audio & Video
Don't know how to install equalizer. Where does
hi input wiring hooks up to speaker wire outputs on the stereo. in 2008 chrysler has no ignition or accessory outputs. everything is digital, if you use a trunkloc from PAC electronics you will be able to hookup your outputs from the deck into this unit and it will provide you with the RCA, and remote power output needed for your system to operate. the factory deck should have battery and ground at the plug but no acc.
Sep 23, 2009 | Soundstream XTA720.4 Car Audio Amplifier
Need info on wiring for audiobahn aeq6q 5 band equalizer
Yes, This connects to the Blue Remote Wire. This will allow the EQ To Power on when in ACC or Start on the Ignition. Please Rate My Response! Thanks!
Feb 03, 2009 | AudioBahn AEQ6 5-Band Car Equalizer
Pyramid eq 906vl no remote lead
that unit use just two power wire you have to connect it to an accessory power source that turn of by your car radio
Oct 08, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
How can i get my power to my EQ?
What kind of eq is it? First thing I would do is hook up the +12 and GND to the same place the amp is hooked up. I think the eq is having a hard time getting ample current, therefore shutting off all the way when the bass hits. Caps are good, but second battery and battery isolator are far superior.
Dec 06, 2007 | Clarion EQS746 Equalizer - 7-Band In-Dash...
HOOKING UP???
im looking of wiring diagram of proline equalizer model GP-870XII
pls can i have a favor to send at my yh act serra_ricky@yahoo.com
tnx!~ and more power!
Sep 15, 2007 | AudioControl EQL 13-Band Car Equalizer
Installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
May 26, 2007 | Pyramid PR333E Home Equalizer
Power Acoustik PWM-19 4-Band Car Equalizer Logo
179 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
