Question about Whirlpool 24 in. GU940SCG Built-in Dishwasher
Only a few of the buttons on the washer setting panel work. Normal won
On the front of my dishwasher only a few of the buttons work. Normal will not light up but my china setting will. Pots and pans won't. I have turned off the breaker to the appliance as suggested but there is no change. It is model GU940SCGQ2. Thanks.
  • 423 Answers
SOURCE: The only number on the nameplate of my
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Posted on Mar 31, 2009
  • 46 Answers
SOURCE: Dishwasher stopped without fully draining water
if it is pluged into gfa plug it might be triped
Posted on Jun 26, 2009
BIKER T
  • 909 Answers
SOURCE: I have a Whirlpool Quiet Partner dishwasher that stopped working
that is a typical indication of a faulty board. once replaced, i suggest a surge plug to be installed. it will protect the unit from future power fluctuations.
Posted on Sep 15, 2009
SOURCE: pots &pans normal sani cycle lighs
If it is a slow blink on the start button it's something to do with your door switch. If it's a rapid continous flashing it's prob a short in your key pad. If it flashes 7 times, pauses and then repeats you have a fault with your heating element.
If it's a short with your key pad and the unit has water in it - stopped mid cycle you can cut the power to the unit at the breaker, open the door controls up and disconnect the 14 pin key pad connection. There should be a wiring diagram in the toekick cover (at the floor). This diagram will tell you how to do various tests, disconnect the key pad. If your not a handy type person call a repair man and tell him you think youhav a short in your key pad.
Posted on Mar 11, 2010
Crew Dawg
  • 275 Answers
SOURCE: The sprayer on the roof
I'd look at the "spray holes" on the sprayer to ensure no clogs.
Next, ensure tube at the back (if I'm thinking of the correct model) of the top shelf meets with the spout sticking out of the baqck wall of the washer.
Posted on Jul 17, 2011
The clean button blinks, yet it won't start?
I had the same flashing light problem first the normal wash flashing light then the others. I tried shuting of the breakers but nothing. I tried resetting the panel by pushing normal wash and heated dry simultaneously and nothing. So I took the six screws holding the front panel out and unplugged the ribbon type wires and plug and unplugged it several times to help make a better contact and I was able to get it to work right away. This may not work for all but I worked for me. It is very easy to do and it's worth a try if you're having the same problem. It took me less then 10 minutes. I had the problem for several days and could not use the dishwasher not mater what tried until I did what I described above. Now I have to see how long it lasts.
Jul 24, 2012 | Kenmore 24 in. 15689 Built-in Dishwasher
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
this probably the thermal heat fuse cost less than 20.00 I think this is whats wrong with mone, light wash works but any setting involving hot water does not, after researching this looks to be the answer and if not I won't go broke.
Apr 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Intermittent problem, unable to select normal wash cycle/start
restart curcuit board sequence
push start hold down air dry and start until lights blink and machine starts then it should work normal
most dishwashers have an instruction booklet behind the botton panel that is nearest the floor you wll have to remove the panel it has a couple of screws. the booklet should be there unless installer took it.
If you omly replaced the front panel board then you may have to replace the circuit board inside the door. It works like a mother board in a computer. Good luck
Nov 17, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Start button on the HMI won't work
There is a ribbon cable that connects to the control panel. Mine was operating the same as yours. I opened up the front and reinserted the cable and its been fine ever since. you need to take all the screws out from the door panel inside the washer to geet to it.
Nov 01, 2007 | GE 24 in. Profile PDW9800J Built-in...
Whirlpool 24 in. GU940SCG Built-in Dishwasher Logo
81 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
