Question about Fuji FinePix A360 Digital Camera
4.1 a360 camera not working
I picked up my camera to shoot and didn't work properly. Without warning my camera doesn't work. I turn it on and the zoom lens gets stuck. the image on the LCD screen is blury and the pictures come out horrible. My camera is part of my hobbie plese HELP!!! Can it be fixed?
  • JANNYR Nov 01, 2007
    TURN IT OFF AND ON UNTIL IT FINALLY FOCUSES
  • amb3r Nov 05, 2007
    i go to turn on my camera, its a fujifilm 4.1 mega pixel A360, and it makes this loud noise, and the zoom doesnt come out, and the pictures are just a blur, and sometimes it just says zoom error.
    Genius:
  • 2,985 Answers
Fuji Support site will quoter a repair price. I suspect it will be well on the way to the cost of a new camera.
Posted on Sep 23, 2007
SOURCE:
Zoom movie
From page 75 of the manual: "The zoom is not available when shooting movies. Be sure to set the zoom before shooting."
Feb 07, 2013 | Canon Powershot A3400 Is 16 Megapixel...
Tip
Fix lens that won't extend fully
If your A360 only extends the lens partway when you turn the camera on in picture mode, there is an easy solution that requires no technical knowledge whatsoever. Mine exhibits this behavior most of the time, and I've experimented it with it and found that these two things help:
1. Hold the power button down the entire time the lens is extending. For whatever reason, this seems to help.
2. If your lens extends only partway (if this is the case the screen and all pictures you take should be blurry), simply hit the macro mode button (the little flower to the left of the zoom) twice. This works because when you go into macro mode, the camera automatically brings the lens to its lowest zoom, which is meant to bring the lens back from a high zoom, but also works in reverse. You may have to repeat this procedure a couple times each time you start the camera (you'll know it's fixed when you no longer hear the motor whine when you press the button).
One last tip: if you've had this problem before and you start up your camera and it seems fine, use trick number 2 anyways, just to double check that the lens is indeed in the correct position. I've made the mistake of assuming, based on the fact that the picture on the screen looked sharp, that the lens was fully extended. When you look at your pictures, you may find that all of them (even those taken with a tripod!) may be blurry.
on Aug 03, 2008 | Fuji FinePix A360 Digital Camera
Zooming issues and no high quality photo
switched it on a off a couple of times and it worked.
Jan 31, 2010 | Fuji FinePix A360 Digital Camera
I get a warning which says *Battery Exhausted*. I've replaced them but still get the warning.. Any idea whats wrong?
earlier i posted solution in similary problem. maybe help you this.
solution is good batteries, Ni-Mh or Lithium, rechargeable only not alkaline. but...problem is how long you watch pictures on lcd display or how much is flash in use. if always by shooting pics used flash that means that you can with best batteries 30, 20 or less pics shooted. and of course, if you connect camera with pc, how long is cam on? just transfer pics on pc and turn the camera off. the best solution is use the card reader for pics transfering.
if is flash off, it's possible to shot 120-150 pics with Ni-Mh. with lithium i don't know, maybe 500 pics. don't use camera lcd for analysing pics it's just there for short preview.
with alkaline batt., very low quality, i shot 30 pics without flash.
i shot also very good pics at night without flash. nikon coolpix L15 can do that but you must have more praxis. alkaline batteries shooting!
after 3 pictures on display is message: warning! the battery is exhausted. what you can do? turn the camera off. wait about 10 minutes. turn the camera on, you can shot 3 or 5 pictures and than turn your camera off again.
you can repeat this few times and you be lucky if you 30 pics captured:)
REMEMBER: all this goes without camera flash!!!
flash and every zooming use more battery power! and that was all magic:).
Mar 22, 2009 | Nikon Coolpix L15 Digital Camera
Need manual for A360 digital camera
The manual you seek is available in PDF format from here:
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a360-zoom/support
Jan 15, 2009 | Fuji FinePix A360 Digital Camera
Zoom won't go in or out canon power shot sd870
zoom will not work in movei mode.
operate zoom before shooting in movei mode.
Apr 09, 2008 | Cameras
Software
Hello.
Please try download and install this drivers, just select the operating system you use.
melnavz
Mar 31, 2008 | Fuji FinePix A360 Digital Camera
Pentax
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
Jun 30, 2007 | Pentax IQ Zoom 60S 35mm Point and Shoot...
Fuji FinePix A360 Digital Camera Logo
74 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
