Question about Kodak EasyShare DX6440 Digital Camera
Kodak dx6440 wont power up lens wont and retract
Hello I have a Kodak dx6440 had it for about two years don't use it much took three pics yesterday and then it just shut down doesn't power up and lens wont retract back in any info would be greatly appreciated thanks den
  • jodiw Dec 07, 2007
    My lens will not retract and power will not come on. Happened out of the blue. It's about 3 years old.
I have the same/similar problem. I could hear the camera attempting to retract the lens. Camera shut down after timeout.
Disassembled camera & found two teeth missing from plastic gear in gearbox attached to lens motor. Don't know yet if part(s) are available.
Camera had light use. Patheticly short life & that Kodak didn't use stronger nylon gears. Bought a barely use Kodak P880 recently, & the autofocus died shortly after. Web search showed others had same failure. I'll never buy another Kodak camera.
Posted on Jan 05, 2008
SOURCE:
It shuts off after turning on and the lens will not retract makes a grinding sound then shuts off
It seems that the one of the gears of your lens has came loose that is why you are expiriencing the problem. This may happen if the camera has been dropped or the lens has been banged.
You should contact the companies repair center to have your camera fixed
Nov 03, 2009 | Kodak EasyShare DX6440 Digital Camera
Easy share V1253...will not stay on...lens will not telescope
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
Hope this helps you out.
Jul 01, 2009 | Kodak EASYSHARE V1253 Digital Camera
KODAK M863 LENS STUCK
Here's what I did...Mine had the lens stuck out and would not power on. Just a green blinking for a second or two. Well, I tried twisting the lens ring closest to the camera while hitting the power button. It's kinda tricky to do...BUT, just keep at it. Mine was a $1 resale shop "find" and now it works. This worked for me. Maybe it will help you!
Apr 18, 2009 | Kodak EasyShare M863 Digital Camera
Turns on then automatically shuts of
FIRST CHARGE YOUR BATTERY OVERNIGHT AND THEN REMOVE YOUR BATTERY FOR ABOUT 10 MINS PUT BATTERY BACK YOU HAVE TO ADJUST THE DATE AND TIME AFTER DATE EVERYTHING WILL BE OK BUT IF YOU ARE USING 9 OR HIGHER MEGAPIXEL YOUR BATTERY WILL BE DRAIN IN THREE TO FOUR HOURS.
Dec 12, 2008 | Kodak EASYSHARE V1253 Digital Camera
Lens jammed will not retract, canon pc1147 zoom
hope this helps.
Aug 16, 2008 | Kodak EASYSHARE V1253 Digital Camera
Hello
wekkkkc kvjbc dhbas jbsa
  • pick ur nose
  • then eat them
Jul 28, 2008 | Kodak EasyShare V530 Digital Camera
Kodak V1003
Hello!!!
please remove your batteries and press the power button for few seconds and replace the batteries now and try switching on ...
Regards
Smilemaker.
Jul 19, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Camera lens will not open
Lens motor shot- contact Kodak repair price likely to be well on the way to a new camera
Jul 31, 2007 | Kodak EasyShare DX6440 Digital Camera
Stuck :(
My Kodak DX6440 did the same thing. After sending it to Kodak's third-party repair (as per Kodak), they called to say it was not fix-able. Kodak's response was "No parts available" and offered 10% off list price of a refurbished camera. ...Big sports ...Way to keep customer loyalty If you choose Kodak, the cameras are good but buy them knowing they are a disposable item. BK
Jan 22, 2007 | Kodak EasyShare DX6440 Digital Camera
Kodak EasyShare DX6440 Digital Camera Logo
231 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
