Question about Garden
No drive I have an MTD JE150/92A - small garden tractor. It has lost drive in both directions. When I select (f)orward the engine note changes and I get smoke appearing from around the area of the drive belts at the front. When I select (N)utral there is still a change in engine tone when I push the speed adjuster/accelerator pedal. Any suggestions would be much appreciated.
  • colinmather Apr 23, 2009
    Yes, The mower can be pushed when off and in Neutral.
  • COUGHY_MAN May 11, 2010
    Are you able to push the mower freely when it is off???
  • 218 Answers
Hi..my name is Keith...and you will have to look at all your drive belt pulleys and physically rotate them to see if any of them have siezed up..also you will have to get the rear axle off the ground and see it you can turn the rear axle drive pulley by hand..with it in neutral and in foward or reverse to make sure that its working properly without any binding..but i do know that the drive belt needs replacing ..if it has had smoke come from it..i hope this helps..if not..please write me back
Posted on Jun 30, 2009
Yard man model series 760-770 Lawn Tractor was smoking a lot. Has oil, grass was thick and a little wet. Could either of these cause the heavy smoking?
over working the engine could have made it over heat that would make it smoke and also damage the engine
Jul 31, 2012 | Mtd Garden
Replaced drive belt on 1985 38 inch cut MTD lawn tractor, belt id smoking
Your rubbing something that's not moving I suspect a belt idler or blade hub, as for diagrams the internet has them http://cf.mp-cdn.net/db/30/8c384c4f3c61628a0487bed5f925.jpg
May 05, 2012 | Garden
I have an MTD Auto Drive Lawn Tractor Model 608 with a Briggs & Stratton engine. When I start it, blueish-white smoke comes out the exhaust in the front; and get worse when I engage the blades. When I...
Could be serious, such as a broken ring or valve issue. Also, could be relatively minor. Might have gas seeping into the crankcase. How full was the oil when checked? Did it look like it was thin and runny, like diluted with gas? If so, change it and put the correct amount of oil in the engine. Run some fuel line cleaner, such as gumout or SeaFoam in the gas tank (about 1/4 cup). That may help the issue of the gas flowing thru the carb and into the crankcase.
Oct 05, 2010 | Mtd Garden
Mtd snow blower,8hp 2 stage, 1995, Problem: oil leaking on axles, and on casing wear axle come out.wheel stop turning , no gear selection. could you direct me ???
The oil leak normaly would make the 'friction disc' inside the frame slip so as to not drive the axle.
Locate the oil leak
#1 engine crankshaft seal
#2 engine crankcase cover gasket
#3 engine overfull so that the excess oil is coming out of the crankcase breather tube and running down inside the frame
Dec 22, 2009 | Mtd Garden
I need a drive belt diagram for a MTD mod# 13am77f7000 38''cut
Hi check out this site its called pats small engines just look up your model
Sep 12, 2009 | Garden
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 | Garden
I need to replace two belts on mtd mower i have no manual
im guessing your question is about the diagram for the direction of belts and which pullys they go on?
i would google it.
google the qeustion but in qeustion somwhere state that you need the belt diagram 1)engine drive belt
2) mower deck drive belt
Jun 24, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Replace drive belt 2004 troy bilt garden tractor 54'' Big Red
Not an easy fix. There are likely 2 belts which should be replaced as a pair. Engine pulley must be lowered to remove long belt. Pay special attention to belt routing. Most times small belt requires removal of transmission pulley. Good Luck.
May 15, 2009 | Mtd Garden
Engin fogs the neiborhood with air filter on.
Sounds like it's pulling oil by the rings/valves -- the air filter is creating more suction. I would try a small amount of an oil additive for high mileage engines. Follow the mixing/proportion directions on the bottle. Sounds like this engine is "wearing out".
May 07, 2009 | Mtd Garden
Garden Logo
83 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
