Question about Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook
Batt light flashes 4 red and 1 green over and over vostros laptop
Vostros 1000. plugged in but low batt light flashes red four times and green once over and over again. What does this mean? Is it a service code for something?
  • Fadeddeath May 11, 2010
    Would I be correct to assume that the system works as normal if it is plugged in but if you remove the charger it powers down since the battery is not holding a charge? Also how long have you had this machine? Are you the original owner?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    What operating system are you using. And are you talking about flashing on the task bar where the battery is an icon or you asking about your adapter...
    Sergeant:
    Novelist:
  • 192 Answers
Hi there. If your battery light is flashing 4 red and one green on the battery light indicator (as in the one next to the power and hdd led), then this is an indication that your battery is nearing the end of it's life, and it's time to get a new one. It will last a bit longer, depending on how much you use your laptop, but there will come a time when it won't work at all.
Tim
Posted on Apr 20, 2009
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Hi. i have a dell vostro 1000 which would not charge its batt so i bought a new batt that had no charge then charged it and it worked once. but now will not charge nor will the batt charge light stay on....
Could be many things, not necessarily in this order, but the ac adapter has gone bad(highly suspect), the power converter/charge board has gone bad, the power plug receptacle has an intermittent break in it from years of use (might be able to re-solder that one back on the board ) - or the new battery is not as new as you thought. In any event, You should send it to an authorized repair center - looking at a $100 bill or more.
Oct 02, 2010 | Dell Vostro 1000 Notebook
My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Dec 07, 2009 | Dell Vostro 1000 Laptop
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
Dell Vostro 1000 will not boot.
It maybe the power adaptor is loose on the motherboard. Push the cord in and rotate it and continuously push the power button if it starts that is your problrm. You can temporarily fix it with tape once you discover where the cord wants to be or you can use a clamp.
Aug 26, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Failure to power up
Check the cable and do power on self test(POST)
Aug 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook Logo
724 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
