Question about Dell Latitude D510 Notebook
Ac adapter's wont charge battery or pwr. unit
Ac adapter's will not charge battery,i have tried 2 different adapter's DELL LATITUDE D510
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
I would say take to a good PC repair shop (Not Geek Squad) and ask them to look at the power jack on the motherboard, it may need replacing. Next would be more of a a motherboard problem and its just quit. Good repair shops could help you either way get it fixed. I don't recommend anyone tackling any sort of laptop motherboard fix unless you really know what your doing.
Posted on May 04, 2009
Dell latitude d510 has no power
Please check out the following steps to confirm the real issue:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
I think the most likely cause is that your dell charger is broken, just try a new charger to test:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Dec 04, 2012 | Dell Latitude D510 Notebook
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
I had a problem with my dell latitude d510 battery so i purchased a new one. And i have to charge the battery but when i plug in the ac adapter, i will see there on power icon that charger plugged in not...
Your charge is bad. Buy a new AC Adapter Power Card. The battery will not charge if the AC Adapter does not work.
I bet if you removed the battery and tried to power the laptop on with just the power cord, it would fail because the power cord is bad.
Apr 04, 2012 | Dell Computers & Internet
WILL ONLY POWER UP WITH THE BATTERY, NOT WITH THE AC POWER JACK
  1. If available, try an AC adapter from another D or E series Dell and see if the system powers on. If none is available, use a multimeter to see if the DC output of the adapter is around 19 volts.
  2. If the system doesn't power on with a different adapter or if the Voltage is good on the adapter, then the failure is most likely the motherboard.
Jan 09, 2010 | Dell Latitude D510 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Dell latitude d510 new battery wont charge
the laptop charger is the problem, try to fix it if you can or buy a new one with warranty..
Sep 28, 2009 | Dell Latitude D510 Notebook
MY BATTERY NOT CHARGING... UNKNOWN AC ADAPTER SHOWING
1st try a different AC adapter. If no change, flash the BIOS, If still no change, Replace the Battery, if issue still occurs,replace the MB
Aug 15, 2009 | Dell Latitude D610 Notebook
Will not run on ac adapt. only battery and will not charge
Check by connecting the adapter to another plug point.
Please check the light on the AC adapter. If there is no light then it is better to replace the AC adapter.
Check the laptop with another AC adapter of the same type. if the laptop works fine with the other AC adapter then replace the adapter
If the light on the AC adapter is on visit the manufacturer's website and try to update the BIOS. If this does not work. check by juggling the connector at the laptop's end. If the laptop charges intermittently or if there is no signs of charging, it is advisable to contact the manufacturer for having the motherboard checked.
Jul 13, 2009 | Dell Latitude D510 Notebook
Wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
May 05, 2009 | Dell Latitude D510 Notebook
Dell Latitude D510 Notebook Logo
303 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
