Question about Panasonic PanaFax UF-8000 Laser Fax
Pages sticking together when transmitting
When trying to fax multiple page documents, machine grabs more than one page and they all go through together. Is this a paper problem? Maybe too humid? Thanks.
  • marsha_schro Apr 20, 2009
    Thanks! I always prefer the simplest solution!
  • 469 Answers
This is caused by the feed and separator rollers are dirty or worn out. The simplest thing to try is to clean the feed rollers. you will need a cleaning solution, isopropal alcohol works very well. Available at local drugstores. you can approach this one of two ways, you can open up the document feed section and manually clean the rollers or put a few drops of Alcohol in the center of a piece of paper let it soak in a little and pass it through the document feeder, the paper should have a streak on the last half of the page if it made contact with the rollers. For best results do this a couple of times, for better results do both the manual and the pass paper methods.
Hope this is of some assistance.
Ed
Posted on Apr 20, 2009
Can't save multiple page scan to multiple page pdf document
that should be because you scanned the pages separately, did you notice if the PDF document converted was the very last page of the 13paged document which you wanted to make a document from? if that's right, then you just only converted the last scanned page into PDF, to stick all the pages together, i recoment you treating them as images and using word to stick them all together with the "insert>image> from archive" adjusting the size of the image at 1 page and with each 13 pages do the same until you have a full document of 13 images in 13 pages then you can convert it into PDF
Sep 14, 2009 | Brother Multi-Function Center MFC-240C...
Comm error 252
The comm error 252 occurs due to,
  • Telephone line conditions were too poor to receive a fax.
This error can be rectified by
  1. Reattempt the fax reception at a later time when line conditions may have improved.
  2. Configure the machine to start reception at a lower speed.
  3. If the local machine successfully received several pages of a larger document, ask the remote user to transmit the document in several smaller parts.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 15, 2009 | HP LaserJet 3050 All-In-One Printer
Will not fax but will receive
Sounds like you are faxing multiple pages through the document feeder and it is trying to grab a few sheets instead of just one.
If you are doing multiple pages make sure they are aligned and separated.
Maybe fan the pages and then pat them on a level surface to make sure they are aligned.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My IntelliFax 2480C is ''grabbing 2-5 pages at a time when faxing.
The separation pad is worn. Thats what keeps more than 1 from going in. It is a rubber rectangle shaped part probably on the upper part of the document feeder that you lift up. They ware out. Lawrence
Jan 01, 2009 | Brother IntelliFax-2480C Fax
Page grabbing
Open the document feeder,you will see in the inside in the upper unit there is a rubber.Clean that rubber with a strong soap.
That rubber is normaly dirty and you have to clean it some times.
If that does not help,you will have to replace the rubber(Separation assy)
Nov 24, 2008 | Canon FAXPHONE L80 Laser
Two problems
Issue 1:
  • Make sure that you fan or flip through the pages before inserting them in the document feeder. This creates air space between the pages.
  • Refer to this link for more information on this issue.
Issue 2:
  • Make sure that ink cartridges still have ink. Replace if needed.
  • Refer to this link for steps to clear faxes in memory.
Nov 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Open the document feeder (number panel). Make sure that a switch actuator is not stuck down.
Jun 03, 2008 | Brother IntelliFax-2820 Laser Fax
I have an hp laserjet 3050 fax machine. When I go to fax several documents at one time, the fax grabs the whole stack and sucks them through. How can I fix this problem?
The first step is to insure that the top cover on the Automatic Document Feeder is closing properly. If it is not, the pages may multiple feed. If that is fine, then there is a pad that separates one page from the next in the ADF assembly. It wears out over time and begins to let the pages multiple feed. The part is normally replaced with the feed roller in the ADF at the same time. These are usually changed by a technician. The part #'s are RM1-0890 for the pad and RM1-0885 for the roller, you should be able to order them online.
Hope this helps!
May 15, 2008 | HP Office Equipment & Supplies
Scanning / faxing problem
you will need to replace the adf assembly or the portion of adf roller which was dameged.
typically one should open th ecover and take out the jam inth direction of papermovement only
happy faxing
omnipresent
Oct 17, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Panasonic PanaFax UF-8000 Laser Fax Logo
305 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
