Question about Nintendo Wii Console
No power to wii console
I have no power to my Wii Console. What could be the problem?
  • ntrotter8911 Apr 20, 2009
    NO power to wii console with all cords plugged in.
    Problem Solver:
  • 18 Answers
Try pluggin the power adaper into a differnet wall socket. Also try pluggin a different device into the socket that the Wii is currently plugged into to test that the socket is good. Make sure all cables are connected firmly including the spot on the power brick. If this does not work then something has either gone bad in the Wii or the power brick is dead.
Posted on Apr 20, 2009
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
Tip
2nd wii remote will not connect
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console.
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
on Mar 04, 2010 | Microsoft Xbox 360 Console
Tip
try this!
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
      Try these steps!
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC" Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
  • on Mar 04, 2010 | Video Game Consoles & Games
    I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
    5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
      Go to the Next Step (Playing Game Discs) >
      One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    3. Select the Wii Remote Settings option from the Home Button menu.
    5. Select the Reconnect Option.
    7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
    Set Up and Use of the Nunchuk
    1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
    2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
    4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
    May 04, 2011 | Toys
    How can i re connect the wii fit balance board to my wii ?
    Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
    The Wii Balance Board must be synced to each compatible game individually.
    These sync settings will be saved even after the console is turned off.
    Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
    Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
    Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.
    Open the SD Card slot cover on the front of the Wii console.
    Remove the Battery Cover on the bottom of the Wii Balance Board.
    Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
    Press and release the SYNC button on the console while the Power LED on the board is still blinking.
    The Power LED will stop blinking and light steadily once the synchronization is complete.
    Mar 16, 2011 | Nintendo Wii Console
    Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
    Jan 27, 2011 | Nintendo Wii Console
    Pressed red button for more than 10 seconds remotes not working help
    hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
    Dec 08, 2009 | Nintendo Wii Console
    My wii unit does't work. There is nothing but a black screen.
    Hi.If the power light is green or orange and your screen remains blank, follow these steps.
    1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
    2. Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved. If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired by a certified Nintendo service tech.
    SYSTEM UPDATE
    If your Wii console is currently connected on-line, you can download the latest Wii System Update by selecting the "Wii System Update" button from Wii System Settings menu. Downloading the latest Wii System Update will add the most current features to your Wii console. If you already have the latest update, on-screen messaging will indicate so after the Wii console searches the available Wii System Updates.
    Oct 23, 2009 | Nintendo Wii Console
    Synching wii fit causes wii console to no longer power up
    1, Turn off and unplug your wii console for a few minutes
    2,Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
    * Then remove the battery cover from the wii remote, inside you will see another red button.
    * Press and release the red button, the blue lights on the remote will start blinking.
    * Quickly press and release the red sync button on the wii console.
    * The remote will stop blinking and it should now be synced.
    then try syncing your wii fit bored
    Dec 28, 2008 | Nintendo Wii Console
    Wii remote keeps beeping and not working
    try this! I found it on Nintendo.com under support:
      Try these steps!
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
  • Sep 01, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    110 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
