Question about RCA P52926 52" Rear Projection Television
Humm It works fine but have a humm. Is it the fan in front of the lenses? I use a seperate sound system so did not think it was the audio. Thanks repairdave
    Champion:
  • 317 Answers
Repair it dave
Posted on Jun 01, 2008
SOURCE:
I have a building to building PA system and in some building I'm getting AC humm through the speakers. Is there a AC filter out there that could eliminate the humm?
You´d better use a power conditioner, such as Panamax. Besides, it will protect the system against power surges and will eliminate the humm.
Sep 21, 2010 | ProSound Power PA System 3 System
Sound from Wonderwall Project
make sure the ground (earth) is good. make sure there are no obstructions in the fan (paper, labels, packing peanuts, styrofoam, etc.). you may need to replace the fan itself.
Dec 26, 2009 | InFocus LP70+ Multimedia Projector
Video1, video 2 humm
Replace C602 on dvd board. noise on 10v line causing problem.
Jan 19, 2009 | Sony DAV-FC7 System
Cold weather does not start
Need to listen for fuel pump humm for proper operation. Shoud humm for about 3 seconds with key turned in the on position. Humm will sound from gas tank where the pump is located. If it does not humm. possible Faulty Fuel pump relay or pump. It will need ferther diagnosis.
Jan 09, 2009 | 1998 Chevrolet Cavalier
Loud humm. I have to keep the volume down when watching the TV.
A humm may be caused by a cable TV grounding problem called a "ground loop." Basically, the grounding for the Cable TV line and the power outlet for the TV are at unequal levels. I had this same humm with both the internal TV speakers and with external speakers (headphones, etc.). The 2 solutions are (1) install a Ground Loop Isolator at the TV, or (2) call the cable company to troubleshoot the problem. I figured the time I saved dealing with the cable company was worth the $50 for the part. I installed the Jensen VRD-1FF which has worked perfectly! Ordered from eBay and saved about $12 over the Jensen Electronics web site price. Hope this helps.
Dec 05, 2008 | Bose Lifestyle 28 System
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Fan not working
the humm could be the contactor check the breaker for the out side unit or see that you have power at the unit dan
Jul 17, 2008 | Carrier 38CKC036 Air Conditioner
Freezer fan noise
What you need is a new updated computer main board. Thay are fairly cheap and easy to install. My GE Side By Side did the same thing and the new motherboard worked like a charm. I think that this is the one you need but you can email the seller with your model number and he will tell you which one to get WR55X10552 GE Refrigerator Mother Board fits WR55X10335s.gif GOOD LUCK
Jan 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
HUMM in phone line(modem)
turn off the mic or the extrernal speaker if this dosent work there might be a problem with the phone cord or your house wires
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 25, 2007 | HP Pavilion dv1000 Notebook
RCA P52926 52" Rear Projection Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
