Question about Cycling
What are my options
I need replacement or repair on my manitou pro xc mach 5 shocks on my diamondback zetec the model is about 8 years old
  • 37 Answers
You must find an independent bicycle shop that does repairs, speciality tools are required to work on shocks, some shops ship shocks to the manufacturer to get fixed. There may be a Manitou warrenty on them anyways, be prepared for it taking a while. REFER TO: Parktool.com
Posted on May 26, 2009
I NEED TO KNOW ABOUT THIS SERIAL NUMBER TO A 20" BICYCLE KW1H00178
I would contact a local bike shop for this information, much better chance of getting what you need.
Oct 13, 2016 | Cycling
Can you tell me what year and model diamondback this bikecycle is serial number is as01lo216o not 100% sure if they are zeros or o's
If the model is not right on the frame the bike has been repainted, which lowers its value. Year is not very important. Serial numbers are not very helpful, but you can try Google search for "Diamondback serial number". Also, see my tip: How to determine the year value etc of your bicycle
Oct 08, 2016 | Diamondback Cycling
How to reassemble diamondback outlook forks
Hi, Hugh for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Diamondback, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.diamondback.com/Data/Sites/12/media/support-owners-manuals/2012_om_diamondback.pdf
Fix Five Common Repairs
Diamondback Tech Fork Sag setup
Replacing Forks Shocks On Mountain Bike
Jul 20, 2016 | Motorcycles
Where can I buy spring suspension fork for 29 inch Men's Genesis Astra GX7? Can I get it online?
to see what you want go to toys-r-us and then go e-bay and see what is available
Dec 07, 2015 | Motorcycles
Wr250f 04 rear shock needs replacing, will a 07 rear shock fit
Hi, Anonymous after careful deliberation 4 out 5 Yamaha Gods give this one a thumbs up, but just to be on the safe side you should give your local dealer's parts/service department a call to confirm. For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Specialized FSR XC rear shock replacements BikeRadar Forum
Adjust rear shock spring on MX bike with no special tools Yamaha example
YAMAHA WR250F Owner Service Manual
OEM parts for Yamaha
YAMAHA WR250R Owner Manual
Apr 07, 2014 | 2003 Yamaha WR 250 F
Sanyo dp42840 42/46 in color tv have no sound or pic
No picture or sound means the main circuit board has failed, in most cases the boards are not repaired but replaced, this is a very expensive repair and so the option of replacing the TV comes into play, factors that affect the decision to repair or replace are the age of the TV, more than 6 years old replace it, less than 5 repair it. The average life of today's flat panel big screens is at best 8-9 years.
Dec 15, 2011 | Sanyo Cameras
Water comeing out cloudy and makeing suds in pool
There could be a few things causing these problems. How old is the sand in the filter? Filter sand looses its filtering ability after 3-5 years and needs to be replaced. If the sand needs to be replaced, make sure you get actual pool filter sand. A lot of big box and home improvement stores sell play sand as filter sand. That will cause your pool to stay cloudy and never clear up. If the sand is less that 3-5 years old, you may need to clean it with a liquid filter cleaner that is poured through the skimmer. This works quite well!
Another issue causing the cloudiness and bubbles could be the type of chemicals you are using. I know that shock from big box and home improvement stores cause the water to be cloudy. Algaecides from these stores also cause foaming.
Jun 15, 2011 | Hayward SAND FILTER, PRO SERIES
Hi! I have a FUJI Thrill LT 1.0 bike frame with no rear shock (2006 model 17'') and I'm trying to figure out which rear shock to buy. On BikePedia.com they say my bike uses a "Manitou S-Type SRL,...
Eye-to-eye is the unloaded distance between the shock mount ends when its on the bike. Unless the shock could squish down flat the piston travel will be somewhat less than its total length. Effective axle travel from shock compression is a function of the bike design and the shock stroke distance. 145mm is the wheel travel, not the stroke.
Yes, they come in different lengths and stroke distances...
http://www.chainreactioncycles.com/Models.aspx?ModelID=46003
again, for different frame and suspension designs. You need to match the spec for YOUR bike. Unfortunately, no one specs the stroke of the shock when discussing the wheel travel. You may need ask Fuji directly.
http://www.fujibikes.com/contactus
Apr 21, 2011 | Fuji Thrill LT 1.0
Loose drum kenmore eliteHE4t
sounds like a broken[ shock obsorber]there are two inside your machine if one or the two fail they will let the drum fall back, sorry but its a repair that would cost a lot of money?might be cheaper to replace machine hope this helps.adrian
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Converting airshocks into regular shocks
aaahhhh, yea if im not mistaken those are the ones that are controlled by computer? my guess would be to find some from maybe a crown victoria and see if they are compatable. or call a autoparts store and see if they carry a non-air version for that car. most of the time, parts on the same make and year of a car will be interchangeable. if they are built around the same frame. like the alternator out of a crown vic would probably be the same one thats in your car for example. but im positive you should be able to get non-air shocks for it, or even call ford and ask what shock were compatable with the mark7. i see those cars around my town and they look like they have been lowered cause the shocks and or the controlling computer have gone bad. i hope this helps but try to see about ones off of a 89 crown vic. i bet they have the same bolt patterns
Dec 17, 2007 | Intel Pentium III Socket-370 CPU to Slot-1...
Cycling Logo
227 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
