Question about Zebra Z4M Printer
Zebra 4 Plus pause botton shows a fast blink when using take-up mode. have to push in peel lever to get it to print. Please help
  • 96 Answers
Power on while pressing cancel key. This will print the configuration. Check print mode. If it is in peel mode change from peel to rewind mode and save. The password is 1234 if you need it to change.
Posted on Nov 21, 2010
  • 31 Answers
Are you sure you are not in peel off mode? It is waiting for a sensor change. When you push the lever, you may have triggered this and allow it to print another label. Put the printer in Rewind mode or something else and see if it changes for you.
Posted on May 27, 2009
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Zebra TLP 2824 Plus does not print barbell labels
You need to run win7 in XP mode. I am not sure the Zebra software will run in 64bit.
Feb 27, 2017 | Zebra Office Equipment & Supplies
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
Hi There How do you print a test page from the Zebra printer itself which shows print head condition etc We've used teh self test print but are lookign for somethign more detailed etc. many thanks
Printing the "PAUSE" test will print a nice black box that will show white lines or voids for any printhead elements that are not functioning. Turn the printer off, press and hold the PAUSE key while turning on the printer. After 5-6 seconds, let go of PAUSE and let the power up self test finish.
The test label will starting printing. To stop, press PAUSE. This is also usefull for seeing the "parallelism" of the printhead by looking at the lines that print at the begining of each label. Should be the same number of lines on the left as the on the right.
Easiest way to cancel the pattern is to cycle power.
Hope that helps !
May 04, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
I am trying to clear the memory on the zebra printer gk420d ... what is the best way to do this?
Hopefully you can read this. I downloaded entire manual from Zebra. This section is the feed button options to reset communications, calibrate, print configuration & also to do a factory reset. You will need to try the FACTORY reset. Basically while the printer is on you press & hold the feed button till it blinks 4 times in a row then release. It will blink 1 time then pause then it will blink 1-11 & pause then 1-11-111 then pause then finally 1-11-111-1111 then release. Each 1 represents a blink. I would attach the doc but system is too busy to allow right now.
Feb 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 4M Plus Pauses unexpectedly
try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
Feb 12, 2008 | Zebra Z4M Printer
Zebra Z4M Printer Logo
358 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
