Question about Canon Cameras
CAN'T USE CAMERA
Canon 450D says my 8 GB sandisk ultra II SD card is write protected please help
  • 4,472 Answers
There is a small switch on the sd card. This can "write protect" the card so that you don't mistakenly write over something important. Move the switch to the unlocked position. If you need further assistance please let me know. also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
Posted on Apr 20, 2009
"Card Write Protected" has come up on my Cannon
Check if the card is truly write protected (check the little slider on the SD card). Its possible it slid into lock position accidentally
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Canon EOS 450D Digital Camera
Is Sandisk Ultra 8 GB SDHC card compatible with a Panasonic Lumix DMC-FZ30GN camera? When inserted in Camera error message check card flashes
No. The DMC-FZ30 was designed to work with SD cards. While SDHC cards will fit into the slot, they do not work. You'll have to use SD cards, 2GB and smaller.
Jul 06, 2010 | SanDisk Cameras
"Card Write Protected" has come up on my Cannon 450D and I am unable to remove it - any help much appreciated. Cheers.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 10, 2010 | Canon EOS 450D Digital Camera
Card write protected
Nov 25, 2009 | Canon EOS 450D Digital Camera
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
Can't format sdhc card in my camera.
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Mar 04, 2009 | SVP CDC-8610 Digital Camera
Problem import picts via sd cardreader (taken with eos 450d)
Some card readers struggle with high capacity (SD-HC) cards and indeed some older devices.
If you (or a friend) has a lower capacity card (less than 2GB) try that in you camera and then pc.
You can purchase a VERY cheap USB card reader (c.£10 max) and it should sort your problem - I hope!
Jan 05, 2009 | Canon EOS 450D Digital Camera
Ricoh Caplio R5 Digital camera
Not many but a FUJIFILM 1 gb card will do the trick
Nov 26, 2007 | Ricoh Caplio R5 Digital Camera
SD card not registering
use only the specified or recommended cf cards, I know ultra fast is not compatible to digicam two or more years older models.
Oct 10, 2007 | Canon EOS-1Ds Mark II Digital Camera
Cameras Logo
147 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
