My emachine shuts itself off, fan working ok, help help
The machine boots itself up fine i'd use it for maybe 4o minutes then it suddenly looses power. id wait a few minutes and id power it back up and it would shut down after another few minutes about 10 minutes. if i leave it off for a few hours it will run a little longer. ive just put a new fan with heatsink, the fan runs fine at start up and continues to run. the yellow light on the front seems to blink alot but im not sure what that means. some one told me its the power supply but im not sure because it does turn on the machine. it doesnt seem to overheat, but it did overheat before so i installed the new fan. please help me id appreciate any advice.
  • 3 more comments
  • CESAR COLLAZOS Apr 20, 2009
    hi guys thanks for the quick responses, well here it is i went into the system bios and this what it has for settings.
    cpu shutdown temp 85c/185f
    smartfan temp 55c/131f
    tempature tolerance (c) 5
    im not sure if those are the proper settings and if thats causing the problem. i then checked the temp and these are the reading
    i also checked the heat sink and its on correctly. should i change a setting. please advise. thx
    system tempature 30c/86f
    cpu temp 78c/172
    system fan sped 0 rpm
    cpu fan speed 2343rpm
    cpuvcore 1.41v
    12v 11.62v
    5v 5.17v
    5v 3 5.00v
    3.3v 3.24v
    thanks
    that heatsink fan is brand new, i just installed it. it runs perfectly, the one i had before was making some funny noises and not running. it seems to be in excellent condition. before i changed it i could feel how hot the pc would get, now it doesnt get as hot since i replaced the heatsink. it doesnt seem to how when it shuts itself off. could it be given bad readings. should i adjust the bios temps.
    thanks again
    it seems to be running the right way, clockwise. i dont beleive there is anyother fan, this is the only one i see in the casing. is their a way to speed up the fan speed. it doesnt seem hot in there at all. before it was very very hot in the casing. thanks again.
    sure i can get that, dumb question on my part, but what is the fsb speed.
    micro star international model ms-7222
    intel celeron cpu 2.93 ghz
    version x86 family 15model 4 stepping 1
    bios- pheonix award bios v 6.00 pg
    i just copied this report from the cpuid hrdware monitor software i dont know if it helps.
    CPUID Hardware Monitor 1.1.3.0
    Mainboard Vendor MICRO-STAR INTERNATIONAL CO., LTD
    Mainboard Model MS-7222 (0x19A - 0x5F1A72)
    LPCIO
    Vendor Winbond
    Model W83627EHF
    Vendor ID 0x5CA3
    Chip ID 0x88
    Revision ID 0x68
    Config Mode I/O address 0x2E
    Dump config mode register space, LDN = 0xB
    0 1 2 3 4 5 6 7 8 9 A B C D E F
    00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
    10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    20 88 68 FF 00 C0 00 00 FF 50 00 7C C0 03 21 00 FF
    30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Hardware monitor
    Winbond W83627EHF hardware monitor
    Voltage sensor 0 1.46 Volts [0xB7] (CPU VCORE)
    Voltage sensor 1 1.83 Volts [0xE5] (VIN0)
    Voltage sensor 2 3.31 Volts [0xCF] (AVCC)
    Voltage sensor 3 3.31 Volts [0xCF] (+3.3V)
    Voltage sensor 4 1.60 Volts [0xC8] (VIN1)
    Voltage sensor 5 1.61 Volts [0xC9] (VIN2)
    Voltage sensor 6 1.62 Volts [0xCB] (VIN3)
    Voltage sensor 7 1.96 Volts [0xF5] (VIN4)
    Temperature sensor 0 33°C (91°F) [0x21] (SYSTIN)
    Temperature sensor 1 54°C (128°F) [0x6B] (CPUTIN)
    Temperature sensor 2 48°C (118°F) [0x60] (AUXTIN)
    Fan sensor 1 2657 RPM [0xFE] (CPUFANIN0)
    Dump hardware monitor
    LPC Register space, base address = 0x0290
    bank 0
    00 01 FF 01 FF 11 00 37 50 60 60 A0 A0 FF FF 03 03
    10 04 BF 10 00 00 01 01 3C 41 17 00 00 57 00 00 C9
    20 AD E3 CF CF C8 C9 CB 21 FF FF FF DA 00 63 CD 7D
    30 4F 65 FA FD EF BA 67 3D BA A9 85 2D AB BB 18 FF
    40 01 FE 9F CE FF FF 00 50 2D FF 40 44 10 15 00 A3
    50 FF FF 80 FF FF FF 20 80 A1 70 FF FF 19 05 FF 05
    60 04 FF 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF
    70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    80 01 FF 01 FF 11 00 37 50 60 60 A0 A0 FF FF 03 03
    90 04 BF 10 00 00 01 01 3C 41 17 00 00 57 00 00 CD
    A0 AD E3 CF CF C8 C9 CB 21 FF FF FF DA 00 63 CD 7D
    B0 4F 65 FA FD EF BA 67 3D BA A9 85 2D AB BB 18 FF
    C0 01 00 10 CE FF FF 00 50 2D FF 40 44 10 15 00 A3
    D0 FF FF 80 FF FF FF 20 80 A1 70 FF FF 19 05 FF 05
    E0 04 FF 40 00 01 01 3C FF 01 FF 01 FF FF FF FF FF
    F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    bank 1
    50 37 80 02 50 00 55 00 FF FF FF FF FF FF FF FF FF
    bank 2
    50 30 00 02 50 00 55 00 FF FF FF FF FF FF FF FF FF
    bank 3
    50 00 00 00 00 00 01 00 00 00 02 FF FF FF FF FF FF
    bank 4
    50 0B 13 FF 00 F8 F5 00 FF 21 DE 19 3B 09 FF FF FF
    bank 5
    50 CF CA F5 FF CD C3 8F 4D D1 66 97 D3 BC 00 00 00
    Hardware monitor
    ACPI hardware monitor
    Temperature sensor 0 55°C (130°F) [0xCD2] (THRM)
    Hardware monitor
    SAMSUNG SV4012H hardware monitor
    Temperature sensor 0 31°C (87°F) [0x1F] (HDD)
    Processors Map
    Number of processors 1
    Number of threads 1
    Processor 0
    -- Core 0
    -- Thread 0
    Processors Information
    Processor 1 (ID = 0)
    Number of cores 1 (max 1)
    Number of threads 1 (max 1)
    Name Intel Celeron 341
    Codename Prescott
    Specification Intel(R) Celeron(R) CPU 2.93GHz
    Package Socket 775 LGA (platform ID = 4h)
    CPUID F.4.1
    Extended CPUID F.4
    Core Stepping E0
    Technology 90 nm
    Core Speed 2927.2 MHz (22.0 x 133.1 MHz)
    Rated Bus speed 532.2 MHz
    Stock frequency 2933 MHz
    Instructions sets MMX, SSE, SSE2, SSE3, EM64T
    L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
    Trace cache 12 Kuops, 8-way set associative
    L2 cache 256 KBytes, 4-way set associative, 64-byte line size
    FID/VID Control no
    Features XD
    Thread dumps
    CPU Thread 0
    APIC ID 0
    Topology Processor ID 0, Core ID 0, Thread ID 0
    Type 01001006h
    Max CPUID level 00000005h
    Max CPUID ext. level 80000008h
    Function eax ebx ecx edx
    0x00000000 0x00000005 0x756E6547 0x6C65746E 0x49656E69
    0x00000001 0x00000F41 0x00010800 0x0000651D 0xBFEBFBFF
    0x00000002 0x605B5101 0x00000000 0x00000000 0x003C7040
    0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
    0x00000004 0x00000121 0x01C0003F 0x0000001F 0x00000000
    0x00000004 0x00000143 0x00C0103F 0x000001FF 0x00000000
    0x00000005 0x00000040 0x00000040 0x00000000 0x00000000
    0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
    0x80000001 0x00000000 0x00000000 0x00000000 0x20100000
    0x80000002 0x20202020 0x20202020 0x20202020 0x20202020
    0x80000003 0x65746E49 0x2952286C 0x6C654320 0x6E6F7265
    0x80000004 0x20295228 0x20555043 0x33392E32 0x007A4847
    0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
    0x80000006 0x00000000 0x00000000 0x01004040 0x00000000
    0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
    0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
    Cache descriptor Level 1 D 16 KB 1 thread(s)
    Cache descriptor Level 2 U 256 KB 1 thread(s)
    Cache descriptor Level 1 T 12 KB 1 thread(s)
    MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
    MSR 0x00000017 edx = 0x00120000 eax = 0x00000000
    MSR 0x0000002C edx = 0x00000000 eax = 0x16110816
    MSR 0x000001A0 edx = 0x00000000 eax = 0x20A60489
    Drive
    Name SAMSUNG SV4012H
    Drive
    Name Flash Drive AL_USB20
    Display
    thanks again
I think the problem is with your processor heating. just download the following utility and see that the processor temp is not going above 65 deg. if so then check the heat sink. your fan is not correctly placed. also when replacing the heat sink did you correctly put the thermal interface material.
check your cpu heat status with this tool...
http://www.cpuid.com/hwmonitor.php
if the heat is very high then try to replace the heat sink or see that it is fitted correctly
Posted on Apr 20, 2009
    Sergeant:
    Novelist:
  • 192 Answers
Hi there. When you turn on your system, enter the BIOS setup screen. Depending on your BIOS, you may have a section that tells you the PC Health Status. If you do, you can check what temp your processor is, and it may even let you adjust the warning temp, (it may be set too low). Some BIOS's will shut down a machine automatically if this temp is reached, to save the integrity of the system.
Yes, you may have a faulty power supply. Try testing it with another and see if the same thing happens. Also, make sure that your power supply is connected to your motherboard properly. Easiest way is to just disconnect it from the motherboard, check for any bent/broken pins, then just click it firmly back into place.
If you need me to clarify anything, just post a comment.
Tim
  • 2 more comments
  • Timothy Farley Apr 20, 2009
    Can you re-list the readings you took of the temps, please. They haven't shown properly.
    You CPU temp is quite high, and your Fan speed is quite low for that temp. It could be that your heatsink fan is sticking.
    Open your system case, look at your heatsink above the CPU. Is it caked in dust? I would imagine it is. Clean it out. Just be careful of your CPU. Make sure you have disconnected the power lead, and you and the pc are not touching anything that can conduct a static charge. To be even safer, take out the heatsink (if you can), it'll be easier to clean too. Once you have done this, put it all back together, turn it on, and check what speed the Fan is running at.
    Let me know how you get on, and let me know the results.
    If the heatsink is brand new, it seems really strange that it's only running at just over 2300 rpm On a CPU running at that temp.
    On the readings you listed, you only 7 degrees of heat left before the system will shutdown. That's not alot of leway. You can increase the CPU Shutdown Temp, but you will run the risk of a CPU meltdown. I doubt it is giving false readings, but it is possible.
    One thing I'd like to ask, is the CPU fan spinning the right way, pulling the air away from the CPU? I know it sounds like a stupid question, but I have seen this done. Also, are you running any case fans?
    I think there maybe a program or 2 you can download to regulate the fan speed, but I'm not sure. Normally you can't change it, as the BIOS senses the temp, and then increases or decreases the fan speed accordingly.
    Under normal circumstances, I would suggest updating your BIOS, but in your case, DON'T do it. If you lose power at any point during the update, your motherboard will be rendered useless. The average temp inside a system is between 27-32 degrees. The reason I ask about case fans, is that, although your case temp is fine, you could run a case fan or 2, which would drop the temp, and in turn, drop the temp of the CPU.
    Can you tell me what motherboard you are running, and in your BIOS, can you tell me what FSB speed you are running at? Also, what speed is your CPU?
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
I have an e-machine T2792. It boots up fine then runs for 10 to 20 min. then shuts down. Could this be my cpu going bad? Thank You Scott
CPU, the motherboard and the rest of the chips in it is subject to wear and tear. This is in addition to the high temperature it is operating with. The sudden shut down is cause by a failure of one component (usually the Processor) who's burned out.
Sep 12, 2010 | E-Machines eMachines Desktop PC
Starts up fine after couple of minutes its shut
Your system sounds like it is either overheating or has a bad power supply If you remove the side panel on you desktop and look at the fan above the processor, it should be running at all times. If not your fan has blown and you must replace it. Please find out what version processor you have before making a purchase, as there are many different types of processors and fans.
Another issue could be poor circulation or inadequate ventilation. Hope this helps.
Good Luck!
JL
Dec 30, 2009 | E-Machines eMachines Desktop PC
Hello, a friend recently brought me a Presario c700 asking me to fix it. When I inspected it, it has occured to me that the entire thing looks completely fine, inside and out, I've checked this thing with...
What I recommend is you remove everything you could possibly remove from the laptop (HDD, mems, cd rom, wifi cards, etc) just to check if it will turn off even when it's not booting or posting. Try turning it on with just the charger and WITHOUT the battery and see if it stays on. If it doesn't, then most likely the mobo itself is the problem.
Oct 06, 2009 | Compaq Presario C700T Notebook
Emachine t6420 suddenly shutting down after about 15 min. - 1/2hr. Power button on HD blinking on and off slowly. Can get it to start up again by taking out the electric plug and waiting a min. and...
Check on the processor installed inside the computer's motherboard, it might be loosen and make sure it is properly locked. Also check for the fan. Make sure the cpu is properly ventilated to avoid overheating that might cause the shutdown.
Sep 28, 2009 | E-Machines T6420 PC Desktop
The PSU fan does not run, computer shutsdown.
Check the CPU fan, it may be faulty and causes the CPU to overheat and shut down.
Sep 02, 2009 | E-Machines eMachines Desktop PC
Emachine shuts off when Windows starts to load
what os are you running? if xp try booting to repair console and run "fixboot" and or "fixmbr".
Jul 15, 2009 | E-Machines Emachine T5026 power supply **...
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
904 people viewed this question
David Payne
David Payne
