Question about Swanstone KSLS-3322 Double Bowl Kitchen Sink, Black Galaxy
Drilling holes/mistakesr I drilled hole in wrong place. Does your company have plug-ins to fill holes?
  • stremd May 01, 2009
    thanks ... found one at menards.... company does not make plugs , referred me to hardware stores.
    Sergeant:
    Champion:
  • 260 Answers
Yes they do you can also get fill cap at hardware stores.
Posted on Apr 30, 2009
Holes missing from 5 tier bookcase metal Putting shelves together. Can I drill Holes in metal?
Yes you can, you just need a drill, the correct size SHARP drill bit, a pin punch - important!! - (to punch a dent in the exact place you want the hole to be - this will hold the drill bit in place when you start drilling)..take you time..use a piece of wood (2x4) to back up the piece your are drilling into... then deburr with a file..
Jul 02, 2017 | Drills
2001 Mercury Grand Marquis the transmission torque converter doesn't have a drain plug. I want to drill a hole for a drain plug. Is there a perfect place to drill the hole ?
If it was me Id just get as much out as you can and go from there,not a hole lot in torque con. and you might be getting into something you don't want to,draining the trans will be enough to get your fluid back into good quality and changing filter,and with every trans change I put a pint of lucas with the change! good stuff!
Dec 14, 2014 | 2001 Mercury Grand Marquis
I need exploded view on 1994 ford escort 5 speed manual gearbox
You should be able to find all you need at the Ford Escort Owners Association website. feoa.net
Oct 04, 2014 | 1994 Ford Escort
Just received a thermocast sink (kitchen) but it was shipped with one hole andI need four. can I drill holes or should I ship this back?
Yes, you can drill them with most any hole saw...just make sure to only use the pilot bit when drilling the pilot hole and then place the hole saw on after the pilot hole is drilled...
Do not apply much pressure to the bit... only enough to give a bit of a cut from the bit as you are drilling the hole.
heatman101
Jul 14, 2011 | International Thermocast Corp Thermocast...
Hi, I want to replace an old American Standard toilet bowl that is a 4 bolt tie down design to the floor. Can I replace this with a standard 2 bolt floor mount design? If not are 4 bolt tie down models...
If you go with the 2 bolt you will need (I presume) to drill 2 holes into the tile. put toilet in place where it will sit and mark the holes , take away toilet and drill the holes with a 7ml tile drill bit (masking tape put over the tile will help you to not slip when starting off the hole). Drill deep enough to insert 7ml rawl plugs. then place the toilet back and fix down with screws long enough to go through the toilet and 3/4 of the rawl plug. You will need; Electric percussion drill or descent battery drill. 7 ml tile drill bit 2 x rawl plug 7ml 2 x screw masking tape is handy hope this helps, Alex
May 18, 2011 | American Standard 2294.011.020 Afwall...
HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
In order to replace the ink..please follow the following steps
#1
Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
#2
Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
#3
Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
#4
Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
#5
Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
#6
Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
Thanks
Oct 06, 2010 | Lexmark X9575 InkJet Printer
How do you fix a freeze plug on a 1987 BMW 325
To remove purchuse a slide hammer can be rented from many auto stores. Drill small hole in center of plus and using the screw end on the slide hammer screw in drilled hole. The hole drilled should ne smaller than the srew end on the slide hammer. Slide hammer until plug comes out. To install: place new plug over block opening and using a socket that fits inside of the center of plug simply hammer until freeze plug is flush with block. I would suggest using fine sand paper and clean up outer edges of block hole surfaces before installing.
Sep 19, 2010 | BMW 325 Cars & Trucks
Got JB weld or braising in my fuel breather
remove the fuel tank leave the cap off and get a small drill bit and re drill the hole using a hand brace or a nut driver. if your careful you can use a battery powered drill or electric drill. why did they cover the breather hole?
Jan 21, 2009 | 1993 Harley Davidson XLH Sportster 883
Swanstone KSLS-3322 Double Bowl Kitchen Sink, Black Galaxy Logo
259 people viewed this question
Top Swanstone Home Experts
Gene Haynes
Tony Crow
Are you a Swanstone Home Expert? Answer questions, earn points and help others
