Home | Ricoh | Aficio 2027 All-In-One Laser Printer | Ricoh Aficio SP 420...
Ricoh Aficio 2027 All-In-One Laser Printer
Problem for Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh Aficio SP 420dn shows SC545 error code after
By koldigs on Apr 20, 2009
Ricoh Aficio SP 420dn shows SC545 error code after power outage. I'd like to know if there is a way to reset. Thanks!
Solution #1
posted on May 13, 2009
Somewhat Helpful)
NALDZ
Rank: Wiz
Rating: 81%, 24 votes
sc545 means fusing section over heat. try 7-807 to reset
Was this helpful?
Yes
No
Solution #2
posted on Aug 18, 2009
Not Rated)
williwilliam
Rank: Master
Rating: 92%, 6 votes
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 2027 All-In-One
Questions and Unsolved Problems for Ricoh Aficio 2027 All-In-One
Do you recommend Ricoh Aficio 2027 All-In-One Laser Printer?
Answer
Answer
I have cleaned the rollers and everything seems like it should work but doesn't.
Answer
it is telling that is has a functional problem, to call for service, I would like to find someone... (More)
Answer
Hello-I can't get my HP 4315v all in one printer to work with Windows XP. I've been to HP's web site... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 2027 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
