Question about Dell Latitude D620 Laptop (Latitude-C620) PC Notebook
Touchpad right and left clickers womt work
I have an hp 6500 laptop. I can move the cursor around via the touchpad but I can not click on anything
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 40 Answers
This is due to the driver missing or uninstalation of the touchpad you must try to reinstall the driver again.
for any harware problem you can check the status in
DEVICE MANAGER present in CONTROL PANNEL(WINDOWS VISTA)
for
WINDOWS XP you can search this application in windows search.
Posted on Apr 21, 2009
Enable tapping on touchpad
on the bottom right corner of your screen there should be a little square that lights up or becomes animated when you more your finger on the touchpad. move your cursor to that and right click it ( put your cursor on it and click the right (as in not left) button and select properties. The option is in there, just look around for it : )
Sep 26, 2013 | Acer Aspire 5610-4648 Notebook
Mouse clicker buttons not working
In Control Panel there is a mouse section, you may have the clicking disabled. if you don't and it still isn't functioning then you have a bad touchpad and it will need to be replaced.
You can also test using a USB mouse to find out if you have clicking disabled.
Feb 26, 2013 | Computers & Internet
Hp g20 touchpad skips
Reinstall drivers. Did you droped your lappy recently ? Have it checked in service !
Nov 04, 2012 | HP Computers & Internet
My cursor moves around but to get any where or scroll I have to left click every time
Enter your control panel from the START menu select CONTROL PANEL open it scroll down to mouse and adjust settings there.
Apr 07, 2012 | HP Computers & Internet
The cursor jumps from line or field on its own...I could typing away and before I know it, the cursor has moved to another field or to the middle of another word! real pain in the ****
You will probably want to adjust the pressure sensitivity on your laptop's touch pad to alleviate this problem. If you have Windows, enter the control panel from the start menu.
1. START > Control Panel
2. Find Mouse or Pointing Devices.
3. Enter the Pointing Devices Control Panel.
Things can vary a bit in this section. So you should look for anything that deals with Pressure settings or Pointing Settings. One setting should be labeled "Touch Sensitivity." This setting controls how much pressure is required on the touch pad.
-If you move the setting lower (or move the slider to the left) this decreases the sensitivity. It is harder to accidently move the cursor if you brush the touchpad while typing.
-If you move the setting higher (or move the slider to the right) this increases the sensitivity. It is easier to accidently move the cursor if you brush the touchpad while typing.
(Note that in some configurations, these are opposite - left to increase senstivity and right to decrease sensitivity).
Depending on your laptop there may also be a setting labeled Touchpad Pressure. It's a setting that resgisters if you are accidently leaning on the touch pad. It's designed to reduce the chance of accidental clicks or motions. This setting is generally controlled the same way the Touchpad Sensitivity setting is controlled, through left-right sliders. I've found that keeping the touchpad sensitivity low makes it easier to avoid accidental cursor motions. I also keep the Pressure setting relatively high as well. One thing you'll note that if you adjust these settings to far into one extreme or the other, you will have difficulty using your touchpad. Fine tune these two setting until you achieve the results you want.
Dec 05, 2010 | Computers & Internet
I'll move the cursor to one spot on the desktop and it will move itself to another....windows 7
You mean, the cursor is erratic and moving all around here and there?
Decrease the Touchpad Sensitivity...
I see that your Laptop was shipped with Windows Vista and it seems you are using a Retail version of Windows 7. Specially, HP/Compaq Laptops is designed for Retail versions and you can face some device/driver functionality issues. But, you can still try the followings.
As per my knowledge, your Laptop has the Synaptics Toucpad.
To Change the Sensitivity of the Touchpad:
1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
2. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings. In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
3. Select the PalmCheck option to adjust the sensitivity (decrease it) of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
If the Device Setting tab is missing.....
1. Click Start, in the Start search field type Msconfig and press enter.
"System Configuration Utility" box will pop up on the screen.
2. Click the Startup tab.
3. Search for "Syntpenh" entry and select the checkbox beside it.
5. Click OK. Restart the computer. Perform above step.
If you are still not able to perform the steps, update the driver from following link.
Synaptics TouchPad Driver: ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44969.exe
Restart the Notebook and check for the problem. It should be resolved now.
Aug 22, 2010 | HP Pavilion dv9000z Notebook
Touchpad has stopped working, can you help?
Hi there don't worry. Its disable that's why not working. Please press FN+F7 and try. The symbol on your keyboard is below. Just press FN+ below mention symbol. Thanks.
Apr 07, 2010 | Acer Computers & Internet
Acer Aspire One Netbook Touchpad
fiddle with your cursor settings in control panel under mouse settings
Mar 14, 2010 | Computers & Internet
Laptop touchpad won't stop scrolling.
1. hook up a usb mouse to get you by.
2. try to download the synaptics touchpad driver.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
see if that helps.
Sep 14, 2009 | HP Compaq Presario V2000 Notebook
How do I partially lock my touch pad so that my palm doesn't screw things up when I type and accidentally touch the pad?
If you look at your touchpad, you will notice a small elongated button, right above it. When you push the button, it will lock the touchpad. However, it will lock it entirely, until you unlock it. You will not be able to move the cursor or click on anything. I don't think HPs have the ability to "partially" lock the touchpad. At least, I was never told anything about it while I was working for them.
May 01, 2009 | Computers & Internet
Computers & Internet Logo
164 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
