Question about Garden
A FRIEND HAS LENT ME THIS WASHER, BUT HAS T GOT A MANUAL
How does one work a Karcher presure washer, K2.35?
    Problem Solver:
  • 10 Answers
Best to run hose for a minute before connecting to machine to clear any debris from hose, plug hose to machine and pull trigger to run water through, plug into power and away you go, when trigger not pulled unit goes into bypass mode, it is advised to not leave in bypass for more than about 5 minutes, this model is light and can easly be over heated so I would advise to switch off at machine and run water through every 20 minutes to half an hour for at least a couple of minutes, after you have finised using unit, switch off at machine, disconect water and power then squeeze trigger to release pressure from pump.
Posted on Apr 23, 2009
My presure washer will not turn on.
does it make any noise when connected to mains,if yes then two possibilities, capacitor is faulty, or motor damaged.
If no noise, then input fuse or motor open circuit. also check cable for damage.
Nov 18, 2013 | Karcher Garden
Karcher KB4040 pulsing when trigger closed and has lost about 50% of its power
Just google " stripping down Karcher KB4040" A YOU TUBE CLIP will show you hiw to fix it and what tools you need
Jun 05, 2012 | Garden
It's a Karcher presure washer K2.54, one and a half years old. Was working fine last time but when turned on now there is very little pressure through the hose and the water seems to be filling up inside...
this sounds like the seals may have been damaged inside the pump or that the water inlet/outlet could be damaged. If you take off the front cover (use a star bit screw driver) then run the pressure washer you will be able to see were it is leaking from and then you can get the right part to replace it.
Mar 16, 2011 | Karcher Garden
How do i get handle off my k3540 presure washer
You need a phillips/cross headed screwdriver and the screw you need to take out are normally at the back of the handle.
Mar 02, 2011 | Karcher Garden
Presure relief value not working when let off trigger on wand
sounds exactly like the problem and the soluition you are looking for.
Mar 12, 2010 | Karcher 2500 PSI Pressure Washer
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
The presure pump is not working.
Try to release the pressure from the wand. Take of the tip if you have to. If that doesn't work take the spark plug out and pull, oil may have gone into the valves. Clean the plug and put it back. It will clear, the smoke that is. Lemme know. Please rate me
Jun 17, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
