Question about HP LaserJet 4650 Color Printer
HP 4650 stops at "initializing"
HP 4650 turns on, does the count up to 128MB, HP logo appears then it stops and only "initializing" on display. I've removed jet direct cards and replaced. I've changed out the formatter as well. Any other ideas or soloutions? Thanks!
    New Friend:
REMOVE THE BATEERY IN THE CARD AND DO COLD RESET
Posted on Dec 02, 2012
Pls replace your formatter card
Posted on Mar 21, 2010
Memory full error
nvram needs reset. 1. Power off 2. Power on while memory count is counting up press and hold green check button till all 3 lights on solid.3. Press up button until nvram init appears. 4. Press select button. can google hp 4650 nvram reset for instructions if these dont work
Nov 06, 2013 | HP LaserJet 4650 Color Printer
HP LaserJet Color Laser Printer 4650dn printer displays 49.5001 Error
Try this....power cycle the printer. When the memory count starts Press and hold the MENU button.
Release the MENU button when all 3 LEDS are lit.
Press the < button
The display will show INITIALIZE DISKS if you did the above correctly.
Press the green CHECK button and wait for the printer to come READY.
Sep 08, 2010 | HP LaserJet 4650 Color Printer Manual...
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
Remove the Jetdirect card and try it. These tend to cause this fault. If not, possibly down to the formatter board
Oct 12, 2009 | HP LaserJet 4650 Color Printer
HP 4650 hangs at initializing
Remove the jetdirect network card. Then power it on and see if it goes ready. If it does then it could be a fault with the jetdirect card
Oct 06, 2009 | HP LaserJet 4650 Color Printer
Message &quot;card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
49.4401 service error on start up
Solution or Workaround:
1) TRY to flash the firmware.
2) Try cold reset and disk initializations.
3) Replace firmware dimm.
If you have a hard disk:
To resolve the issue it may be necessary to perform the Disk Init procedure.
Disk Init Procedure
1. Turn the printer off, then on
2. When the memory count starts on the control Panel, press and hold the Menu button until all 3 lights on the control panel are lid
3. Press the < button. The message “INITIALIZE DISK” appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it’s power-on sequence.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP LaserJet 4650dn Printer
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
My Printer has an Error Message saying "card slot not Initialized
Try this.
1. Turn the printer on.
2. When the memory count start Press and Hold the "Menu" button.
3. Release the "Menu" button when all 3 LEDs are illuminated.
4. Press the 'back' button.
5. The display will then show "Initialize disks".
6. Press the green "Check" button to start the process. This will take some time.
7. The printer will automatically come back to "Ready" after this procedure.
If the above doesn't work, you may have a bad memory card.
Jan 22, 2009 | HP LaserJet 4650 Color Printer Manual...
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
HP LaserJet 4650 Color Printer Logo
490 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
