Question about Hitachi 43FDX01B TV
Poor color My Hitachi 43FDX01B TV has worked great for six years. A few days ago I noticed the color not as good, i.e. flesh tones were reddish and the overall picture was darker in color tone. I had the color setup on UltraAI since we had the set. Everything was OK. Now I've had to adjust the color tint down and turn the brighness all the way up. Even tried adjusting the tint, but just not as good. Obviously, something has gone wrong, since I've never had to adjust the color at all. Is this a common problem with this TV? Is this a major problem to get repaired? The convergence looks fine, no problem with that.
  • 1,139 Answers
I am about to say something that may sound stupid but it sounds like you are experiencing this. After years of use you CRT guns in your case the gun in each one of your CRTs(RGB) begins to oxidize and decrease in its ability to provide electrons for the scaning beam this creates a dark picture. Common problem? yes, over time, but for it to happen in just six years is strange but it can. Major Problem to have repaired? No, the technician will use a CRT rejuvenator on all three of your guns and then balance them and you are off and running. Now the other problem that might be occuring low CRT anode voltage. this could happen. Common problem? yes, it is the best choice Major Problem to have repaired? yes and no depending on which components are bad.
Posted on Sep 21, 2007
I just replaced six resistors and heat sinks on my Hitachi 43fdx01b
2.2 is red,red and 1.5 brown, green---no polarity.
if you did not change the chips or poor soldering,,,,,,,,
Jun 26, 2012 | Hitachi 43FDX01B TV
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Jul 09, 2009 | Hitachi 43FDX01B TV
Well i really want to know what level the coular and brightness lvel has to be on a toshiba t.v
You can set these controls to your liking, though a lower brightness setting might increase the life of the screen. First, set the brightness and contrast to a level that is pleasing to the eyes, then adjust the color to look realistic - enough color without being disturbing. If faces area look greenish or purplish, then also adjust the tint (sometimes called Hue) until you get accurate flesh tone. Flesh tone is the best thing to adjust for; when you get good flesh tone, the rest of the picture will look great. ALWAYS make adjustments during a live news broadcast, which tends to have the most accurate balance of brightness, contrast, color level and hue. Note that commercials are all recorded in different studios with different settings, and will usually not look right - it's best to just live with this than to constantly readjust the TV. There are also DVD's available which walk you through proper TV adjustment.
Jan 02, 2009 | Toshiba 36AF41 36" TV
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Projection tv has a reddish tint on the screen and appears to look hazy and flushed. Flesh tones have a red/orange hue.
first try adjusting the color-tint on the menu if this does not solves the problem you have a failing proyector and has to be replaced
Apr 03, 2008 | Televison & Video
Problem in Hitachi 43" tv
Common failure called convergence mis-alignment.Needs
convergence IC's replaced by skilled technician.Good set
to keep going a few more years.............T.
Please rate this solution...................
Nov 15, 2007 | Hitachi 43FDX01B TV
Purplish-reddish flicker on Hitachi
It seems you might have cold solder connections on the picture tube socket or on the picture tube drive board. If your not a tech please call someone to assist you with repair as you can be seriously hurt by the HI voltage insiode this set an or cauae more problems with the set. Good Luck
Aug 03, 2006 | Hitachi 43FDX01B TV
Red Lines On Screen of Hitachi 43FDX01B
can we see a picture of that?? I dont understand whatyour saying about the lines.. Are they differant colors or all red and do they make the pic bow?? does the pic look or have a reddish tinge to it?? is ther too much red in the picture??? Please let us know or let us see??
Apr 11, 2006 | Hitachi THE SOLUTION 3511 Projector, Mount...
Hitachi 43FDX01B TV Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
