Question about IBM ThinkPad 600E 2645 Notebook
Error code 174 on startup?
I have an error 00161 and 00163 on my thinkoad how can i overide this issue
Posted on Jun 01, 2009
    Problem Solver:
IF YOU CAN USE A SOLDER GUN YOU CAN FIX THE CMOS BATTERY. the battery is located under the access plate that covers the ram cards. simply unplug take wrap off battery cut wire off battery get new battery and solder wires on new battery. then plug up. i had to do the samething for mine
Posted on Jun 15, 2009
  • 400 Answers
That usually means a bad CMOS battery (its like a watch battery that stores your systems settings and time)
It will have to be replaced by you or at an IBM authorised support center.
Here is someone who solved it:
http://forums.techguy.org/hardware/346625-ibm-thinkpad-600e-massive-error-2.html
Posted on May 12, 2009
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Error code P 171 and P 174 and P0443
Type: OBD PO 171 --for the code discription,
cause & solutions
OBD PO 174
OBD PO 443
Sep 16, 2013 | Ford Windstar Cars & Trucks
2005 ford explorer had sudden loud knocking and codes P0174, P0300,P0316
Well code 174 is for a lean fuel system on bank two.
Code 300 is for a random miss and code 316 is for a miss on startup.
For some reason you may not be getting enough fuel to the cylinders on bank two, or you could have a major vac leak.
Dec 24, 2012 | 2005 Ford Explorer
P1619
Hi David:
P1619 is a thermostat error, you likely need to replace it or you have a bad sensor. P0174 (I'm guessing that's what you meant, not just 174) is a bit trickier to troubleshoot. There is a good video here showing where to start:
Feb 10, 2012 | BMW 330 Cars & Trucks
Call for service. U2-40
perform the following procedur to reset the error code:-
Clear key ® Interrupt key ® "R" key ® Interrupt key ® 16 ®
Start key
Jan 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
When trying to install FIx It Utilities 10 Pro I get a 'Fatal Error'message that says 'Installation ended prematurely becasue of an error. I have tried diabaling all Firewalls and virus checkers and even...
Do you had all
System Requirements
  • Windows® XP, Vista® (32-bit or 64-bit) or Windows 7 (32-bit or 64-bit)
  • Internet connection required for product updates and registration
  • Internet Explorer 5 or later.
Dec 05, 2010 | Avanquest Fix-It Utilities 10...
My printer OCR command does not respond. The printer says it's connecting to the PC but after a short period reverts to standby.
  1. faq000559_002 When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with OCR or the Brother ControlCenter3, the text comes out as gibberish. This started after I installed Windows® XP Service Pack 2 (SP2). Why and what should I do?
  2. faq000093_012 What is MFL-Pro Suite Software?
  3. faq002613_000 When I try to scan to OCR I get an error message saying "This feature is not available because there is no OCR Software installed".
  4. faq002561_000 How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
  5. faq000562_002 When scanning to OCR from Brother Control Center3, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  6. faq000563_002 When scanning to OCR from PaperPort® SE, the following error message appears: "System error incurred in external ink module EZText.g32. The OCR server is unable to process the document". I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  7. faq002620_008 Windows® 7 Support Information
Oct 26, 2010 | Brother DCP-330C All-In-One InkJet Printer
My sony vaio computer only run on safe mode but not on normal mode..., no audio..., what do you think is the problem
What happens if ypu try to start in normal mode? You can force a normal boot by presing F8 when the PC is booting to see the advanced startup options. If you are getting a stop error then please get me the error code so that I can help you troubleshoot.
Sai.
Oct 01, 2010 | Sony ® VAIO® V TV-PC Series -...
Computer gives me blue screen with huge error code. and will not do any thing else. does this mean computer is dead? jim
You need to repair the operating system because it seems to be there is some operating system files got corrupted.
Nov 09, 2009 | Dell Dimension 3000® Pentium® 4...
Keep getting "Not Responding"
Run msconfig command in run window and got startup tab and disable all the items and restart the system .
Sep 17, 2009 | Dell Dimension 3000® Pentium® 4...
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
343 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
