Question about Mag Innovision LT765b 17" Flat Panel LCD Monitor
Monitor display shifted offscreen
Every time i reboot, switch graphics modes (from computer games), or change the refresh rate, the desktop screen is shifted to the left. There is a blank space to the right of the screen. I can fix it by resetting the monitor settings. I have a MAG innovision 17" LCD flat panel monitor.
  • 68 Answers
I would be carefull with refresh rates unless you know the maximum and minum rates to apply to your monitor. I solved this problem before for someone and what i recomen is to set your normal desktop to the same resulution as your computer games. That way when you leave your games or reboot it will be the same. See what is happening is when you play your games it is a higher resultion then your normal desktop. And when you log off from it your monitor has to re adjust to the old settings. This will cause a shift. By setting them both the same you will avoid this problem all together.
Posted on Sep 20, 2007
Borders on external monitor after Dell Latitude D630 wakes from sleep
Thomas Motley,
Your monitor is displaying like it is because the graphics card refresh rate has changed. Check that the display driver is correct for your graphics card and that you are not using the generic windows driver. If the driver is correct then look in desktop properties, settings, advanced, monitor and check that the refresh rate is correct for you monitor.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 27, 2013 | Dell LATITUDE Computers & Internet
My computer monitor just has a window open that says ( D-SUB out of range 53.6khz/85hz) how can I fix this ?
1. Turn off your computer (you can do this by holding down the power button).
2. Making sure the monitor cable is plugged into the computer, turn the computer back on.
3. If there is something other than the error message on screen, begin tapping the F8 key on the keyboard as soon as the computer turns on. 3b. If nothing (other than the error) is shown on the screen after restarting, you must obtain another monitor and follow these steps from the beginning on that screen.
4. After less than a minute, you should get a menu like this
5. Select "Safe Mode" 7. Once at the Windows desktop, right click on the background, and select properties.
8. Select the "Settings" tab, and move the resolution slider all the way to the left.
9. Restart normally, and once in regular Windows, repeat steps 7 and 8, selecting the resolution of your choice.
Mar 05, 2011 | Computers & Internet
I have a dell dimension 8400. The graphics card has VGA, S-video, and DVI outputs. I want to connect my plasma tv. I purchased a DVI to HDMI adapter and connected the two with an HDMI cable, but the...
You may have left out a couple of steps.
Now, you need to configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab.
The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate.
If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
Now, again, reboot your PC to apply the changes.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Dimension 8400 PC Desktop
Monitor will not support refresh rate, how do i change it if I can not get a screen image?
Try loading windows in Safe mode. And remove or disable the Radeon card, Safe mode will load windows generic video drivers, then go to control panel, and click on device manager and then click on display adapter, and delete the driver, you must delete it or the Radeon card will reload its driver the next time u reboot and you problem will not go away.
Please leave comment...
Oct 12, 2009 | ATI RADEON 7000 32MB DDR AGP Video card...
Monitor flickers
Goes in the config panel, in display section, then the parameter tab, chose advance button.Then usually under the monitor tab, you'll find a refresh rate settings. Try 70hz setting. Also some time not using the protected ''power bar'' and connecting direct to wall helps alot. Let us know!
Oct 10, 2009 | IBM NetVista X41 PC Desktop
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Kindly rate me if i was helpful.
Aug 25, 2009 | Hansol Computers & Internet
No graphical display during booting up of windows XP. After a while an on screen message is displayed as "High resolotion not supported" . No problem when a live CD (Linux) was used.
you might have changed the screen resolution or the refresh rate that your monitor might not support. So you better get into the safe mode by clicking the Function key 7and 8 then use the option called safe mode.
After the windows starts log in to the administrator profile, right click the mouse on the desktop then select properties. A display settings window will pop up, in that change the screen resolution to 1024X768 and bring the monitor frequency rating to 60 or 75 Hz. Now apply the settings and restart the system in normal mode.
If still the problem persist then in the monitor control select "auto adjust" to get the things done.
Aug 06, 2009 | Compaq MV 540 15" CRT Monitor
Acer al2016w monitor
when you say you have it plugged into the on-board video output.. does that mean there is a graphics card installed too? used to be graphics card installed? if there is or was then its possible that there is a bois setting that tells your computer to use the existent or non-existent graphics card. either was your onboard is going to shut down. This is one theory.. but since its is turning off once you get to your desk top the more likely reason is that its software based and you either have the wrong resolution, driver, or refresh rate selected to use when windows boots. Toy around with diffrent resolutions, refresh rates, also if you have a graphics card plug it into that. your on board most certinly will not be enabled if you have a graphics card.
VGA MODE in vista:
Restart the computer and immediately start pressing the F8 key, once per second. At the selection screen, use the up/down keys to select "Enable VGA Mode", then press the "Enter" key.. If it works, it will bring up the basic VGA drivers in "normal" Windows and should allow you to install the Vista compatible drivers for your new card. After installing the new drivers, restart the computer and if it remains in VGA, you should then be able to adjust the resolution, etc. from the "Display Properties".
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Screen flickers badly at the resolution i want to use and no option to alter refresh rate - any ideas?
I assume you're using windows XP or Vista ? The OS uses data from the monitor to tell it resolutions and refresh rates supported. If you get flicker and cannot alter the refresh rate, it is because the monitor will not supprt a fatsre refresh rate. Your only option, unfortunately, is to get a new monitor, or the cheaper option, use a different resolution.
Nov 26, 2007 | Gateway FPD2275W LCD Monitor
Mag Innovision LT765b 17" Flat Panel LCD Monitor Logo
176 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
