Question about Dell (S423) for Dimension 8100 (3F546) Motherboard
Dell Dimension 8100 Power On Reset Problem
Started with a Dell 8100 that would init. video on power up. Found that after being powered up after at least 30 min. or so that I could unplug the AC cord and replug quickly and get POST, BIOS setup, and boot to a known good Windows HD. Thought it could be power supply as its voltages were down below 5v somewhat so replaced with new DELL PS. System still exhibits the same problem. Looking for a hardware reset jumper and cant find one. Cant find pinouts on front panel ribbon cable connector. Used old PS, cut the power good sig. and then connected well after power up to see if that would force a power up. No change in problem. When I tricked it on with the power cord it ran several days and appeared stable. Removed video NVideo card, cleaned contacts and reseated. Reseated all RAM. Yellow and Green LED on MB come up when power is applied. Now getting more difficult to reset, even with re-plugging ac cord. Cant find schematics or pinouts for connectors. Thanks to all.
    Brigadier General:
  • 6,966 Answers
Hi, Considering that this motherboard/model is a couple of years, it may be possible that: 1. Components have changed value seriously affecting performance. Predominant are capacitors near the CPU that have blisters, swollen or lost part of or completely its storage capacity. Next in line would be resistors and regulators specially those close to the memory slots. 2. If you have any USB device connected, try removing them while booting; 3. BIOS may be outdated/corrupt, flash the BIOS to the latest firmware if and when you were able to boot it up using the fdd (pls be informed of the inherent possible failure when flashing). On your other concerns: a. "...reset jumper..." - temporarily short the RTCRST pins near the battery. You may also try moving the PSWD from its default position (enabled) to disabled; b. "...pinouts on front panel ribbon cable connector..." sorry even the Dell site that I have access does not have info. It might be a bit difficult getting a replacement motherboard being a socket 423. Another item to be taken into consideration is that your motherboard still uses PC800 RDRAM 184-pin RIMM Memory. To sum, if you will replace the motherboard, chances are you will also have to replace the processor and memory. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 21, 2007
SOURCE:
Sharp TV lc-60le640u
Unplug set, press and hold (on set) volume-down and channel-down and hold them while plugging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state'
Dec 05, 2017 | Sharp Televison & Video
Sharp TV model lc-60le640u
Unplug set, press and hold (on set) volume-down and channel-down and hold them while pluging in set. Will come on with "k" on screen, or will crash again if backlight bad. If it stays on, use your remote and arrow right then look for "fact init" and any other reset and turn them on. Arrow back up to "fact init" and hit enter. Let set recycle to green and unplug/re-plug in 5 seconds: the set should be in OOB state'
F8 key will not work
turn off your laptop, remove the power cable and battery then press the power button for 30 seconds...
wait for 1 min....insert the battery ..power on laptop and then check...
Jul 31, 2012 | IBM Lenovo IdeaPad Z565 Notebook
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Nov 17, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Exact Same Problem
Wow heard they have bad power supplies , you may want to check into it as they overheat the cpu's and this is the cuase, Dell in my book is not a got brand however Hp would be a better choice for a computer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | Dell Inspiron 530s Desktop Computer...
Load Paper
Do this: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-On
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 03, 2008 | Office Equipment & Supplies
Dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Oct 18, 2008 | Dell Dimension 3000® Pentium® 4...
Dimension 5150
I think that your SMPS is no working properly..
you may need to replace it !!
Mar 10, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Boot Issues
I've seen the same problem fixed it with new power supply. The old one was losing full power.
Oct 08, 2007 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Dimension 8100 Power on reset
go back to where you did this ... "after leaving the power on for some time (>30 min.) I tried un plugging the AC cord and immediately plugged it in and got POST and BIOS setup and a good bood to a known good hard drive. Left it on for 3 days running AutoCAD, ran reliably."... do that again, but this time, leave the pc on and turn it off using the hibernate feature (must enable it first) as a test of potential faults.
Sep 20, 2007 | Dell (S423) for Dimension 8100 (3F546)...
Dell (S423) for Dimension 8100 (3F546) Motherboard Logo
293 people viewed this question
Ekse
Clive
Clive
