Question about Andis 01690 Hair Trimmer
Misses hair when cutting
My Andis improved master clippers are not cutting right. it seems there is not enough movement in the blade. i have to cut VERY slowly. If I cut quickly it leaves 2 small stripes about 1/3 and 2/3 of the way across the cut. looks like ...|...|... The blade is clean, sharp, and well lubricated. power adjustment is adjusted to just before loud noise
  • mikeisspidey Oct 09, 2009
    I fixed it. the screw on the inside that holds the lever on, closest to the power cord was too tight. works perfectly now.
  • Anonymous Mar 19, 2014
    Clippers cut out and overheat
  • 32 Answers
Try adjusting the screw on the side of the clipper
Posted on Oct 08, 2009
  • 3 Answers
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Posted on May 25, 2009
Andis agc 2 not cutting very well
Yep as simple as that just make sure they are a well recignised sharpener otherwise you will waste your money. You can rule out a clipper problem if other blades cut ok. Clipper Blade Sharpening
Mar 03, 2013 | Andis AGC2 Hair Trimmer
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
When i cut hair my andis master clipper seems to get stuck while cutting hair causing me to take longer with the fade how do i go about fixing it to where it doesnt get stuck in hair & by the way im...
mcdevito75 here, Sounds like the blades need to be sharpened, refer to the shavers brand name plus .com for blade replacement or replace the shaver.
Jun 19, 2010 | Andis 01690 Hair Trimmer
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
My 78950-100 will not cut my dogs hair
The clipper that you purchase dose not have the power to cut the Dog fur, You need a Andis Xcel 2 speed with a # 10 clipper blade. www.mannyssharpening.com this clipper is quiet and has power. askmannyssharpening@yahoo.com
Feb 04, 2010 | Oster 78950-100
Andis pm-3 dog clipper won't cut anymore!
I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
peony
Mar 02, 2009 | Andis ProMotor PM-3 Hair Trimmer
My GTO model Andis clippers blade is not properly aligning..how do I adjust it?
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
Andis 01690 Hair Trimmer Logo
913 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
