Question about Philips 60P8341 60" Rear Projection Television
Power light blinks 4 times the pauses the repeats?
I have a philips model # 60p8342 i purchased for seven dollars at a recycle place because it looked to be physically in good condition. i knew that it did not power on but i figured for seven dollars i would take a chance and see if i could fix it.
know the problem is when you press the power button there is a chirping sound the comes from the middle center of the center pc board(the one that the high voltage line from the tubes go too). it chirps for about 10 to 20 seconds then stops. then the power indicator on the tv blinks red 4 times the pauses then repeats.
i have check all fuses and they are go i have check the relay just behind the big transformer and it is good. i have removeed the center board to examine it more closely and i don't see any damage (i.e melted traces)
  • moldrodger Apr 30, 2009
    i replaced both stk392-110 ic's with the recommended stk392-150, on the ssm panels. still getting chirping sound from the cba panel . when the chirping stops the power light blinks red 4 times and then pauses and then repeats.
    correction not cba panel, lsb panel
  • 15,935 Answers
Click here for your owners manual in PDF format.
When Flybacks fail - they cause chirping sounds you are experiencing.
Your set has gone into protection due to the shorted conditions that have developed.
Both the main power supply and the high voltage flybacks can cause the chirping and beeping sounds.
Phillips sets are extremely hard to work on - even professionals cringe - because they do not have good support, parts availability, or available service manuals.
The quality of the repair depends severely on the ability of the repairer.
My suggestion is to call Philips direct - supply them with your model # and ask for part numbers for the power supply and high voltage flybacks.
When you contact Philips please have available:
  • The exact model number
  • Your date of purchasing
  • The serial number of your product
power light blinks 4 times the pauses the repeats? - icon_phone.gif Speak with a Philips representative
1-888-744-5477 Monday - Saturday 8:00 am - 11:00 pm EST Sunday 9:00 am - 6:00 pm EST Excluding major holidays
Thanks for using FixYa!!
Posted on May 01, 2009
  • 10,515 Answers
Hi moldrodger,
The chirping you hear is the switch mode transformer trying to supply enough current to the convergence circuit, when it cannot achieve balance it will stop and re-try to supply power. The actual chirp is coming from the coils as they reach max current capacity. When you lifted that connector, the power to the convergence circuit was removed. This removed the load on the power supply which allowed it to come up to the proper voltage without maxing out the supply’s current capasity. You may have blown a fuse on the power supply board. The microprocessor is sensing the loss power to the convergence circuit and muting the video and audio.(some models you can get the picture to come up but not all) The convergence ic's have failed again. There are several possible explanations for your problem.The most common problem is that the ic's you used were inferior this problem is such a prolific problem among all brands of big screen tvs. There is a huge market out there selling horrible ic's for as little as $6.00 each. Praying on the inexperienced repair. I know i have been through this before. At our shop i got them to only buy our ic's where they are known high quality. But the only problem with this is they are about 30.00 each. But they work! The parts store is a good place to find them as well. Also if the original ic's were stk392-110 or stk392-120 replace with either stk392-150 or stk392-180.The second possible issue is that you did not replace the heat sink compound on the back of the ic’s this will cause the new ic’s to quickly overheat and short. The third possibility witch I have only seen with is that you can over steer the convergence causing the ic’s to draw more current than is necessary to converge the set, there are other methods designed to get the convergence close to correct without using the convergence to get it right. You may need to use these methods before you attempt to do a digital convergence. In every case that have had repeat failures, one of the three above problems needed addressed to fix the set and keep it from coming back. I have worked on 100’s of tv’s with this problem.
I hope this would be fix this yourself.
Any further assistance, let me know.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Posted on Apr 20, 2009
What is the part number that corrects the seven blinking lights on a panasonic plasma tv model tc-50pu54
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 15, 2016 | Panasonic Televison & Video
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
Won't power on
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Jul 19, 2013 | Philips 47PFL7422D/37 Television
Power button blinks red seven times on a 2007 Panasonic flatscreen VIERA.
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The "pop" is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Jan 15, 2013 | Panasonic VIERA Televison & Video
Mitsubishi WS-55819 turns off after about one second upon power up. Help
try the self test: when it goes off press and hold the menu and input buttons at same time for about seven seconds and release both.
power light blinks two digit code like, one blink, two blink, a pause and repeats it several times, this code will indicate area of problem.
sj
May 17, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Screen will not come on when trying to power it up. the power button blinks red 7 times, then pauses, then blinks 7 more times. it will repeat this process over and over. t.v. will not come on...help!!!!
The blinking seven times is a fault code to locate which area of the TV has developed a problem, this is a protection mode to prevent further damage. I would need to know what model of TV you have to try & give you an idea of which section of the TV is at fault. This could be a power start up or scanning fault.
Oct 07, 2009 | Philips Televison & Video
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
