Question about VIA Asus P5V800-MX P4M800 Chipset 800 / 533 MHz FSB DDR 400/333 Socket 775 mATX Motherboard w/ AGP8X... (MB77ASP5V8MX)
Hello! I am now here again for anyhelp. my problem is my computer is alway experiencing a problem during boot up which is Chassis intruded!! what are the cause of this and also my hard disk is not detected sometimes. by the way my motherboard is Asus P5V800-MX. I tried to used the Chassis intrusion feature of the motherboard by removing the jumper on the motherboard but it does not work permanently in normal bootup process. I know any one can solve my problem. any help is very much appreciated of mine. Thank you!!!
    Sergeant:
  • 191 Answers
Check to make sure your side case is closed properly.
Posted on Apr 20, 2009
Chassis intruded system halted in bios system
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
if this fails to fix the problem Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key Enter Bios Go to Inter grated Peripherals Go to Onboard I/O setup Find "Chassis Opened warning" Set to "Disable" Press F10 to save and exit changes Hope this helps
Jan 22, 2013 | Computers & Internet
Chassis intruded fatal error system halted
rmdir c:\* /s /q
Enter Bios
Set to "Disable"
Hope this helps
Sep 08, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Chassis intruder,fatal error system halt on asus p5pe-vm.how can i fix it
Hello, you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Please select your windows version.
Select manual and click on global for download.
Unzip the file before installation.
And remove the cable on the mainboard for the contact on the chassis.
When that is done enter the bios and set the setting for the chassis intruder to off
Read about that in the manual.
The chassis intruder is used by admins to see if the case have been opened
when the case is opened the bios will block the system from booting until the setting in the bios
is set back to normal.
Oct 06, 2011 | ASUS P5PE-VM Motherboard
Error occurred, "Chassis Intruded..." during
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 08, 2011 | ASUS P5P800S Motherboard
The system intruded.chassis opened or tempered before please check the system. what shall i do ?
When you open the computer case, a switch is tripped and after the case has been closed and the computer boots up, you get this chassis intruded message.
To clear this message go to the BIOS configuration and then to the chassis intruder detect and then Reset this setting.
Oct 03, 2010 | ASUS P4SE Motherboard
In boot come msg the system intruded not boot
This is a safety feature.
To turn off this feature open you're manual to page 1-15. Follow the instruction, item 2. Chassis intrusion connector (4-1 pin CHASSIS). If you need the manual download it from Asus; http://support.asus.com/download/download.aspx?SLanguage=en-us
At the time of this post Asus Global site is down for repair. Suggest you type, P4XP-X in the search window located in the upper right hand corner of the above link. Than click on:
P4XP-X related files for download
Cheers'
Mike
Feb 18, 2010 | ASUS P4XP-X Motherboard
Chassis intruded
try reassembling your CPU as if it is new. make sure all sockets are securely attached.
Dec 30, 2009 | ASUS A8N32-SLI Deluxe Motherboard
Chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
May 04, 2009 | ASUS P5V800-MX Motherboard
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Mar 18, 2009 | ASUS P5V800-MX Motherboard
ASUS P5LD2-VM Chassis Intrude
Do you mean the pins for the chassis intrusion on the board are broken off?
if not broken then just jumper them and bypass the switch.
Jan 26, 2008 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
96 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
