Question about Royal 160MX Shredder
Royal 160MX continuously runs
Approximately 5-10 seconds after turning the unit on, it starts to run and will not stop. There is nothing in the feeder and everything appears normal. I can push the reverse and it will stop, reverse, stop, then start forward again. I have to turn it off to stop if from running.
    New Friend:
I used alcohol on a q-tip to clean the sensor. I completely dissasembled my unit only to find it was unnecessary. The senosors are in the middle of the slot above the metal roller bars. There is a small 1/16" photo sendor on either side of the slot in the middle. they look like small holes in a square area. (Royal 15mx)
Posted on Apr 05, 2013
  • 469 Answers
Blow out the sensors with some compressed air (Computer Duster). Some times a build up of paper dust will cause the sensors to beleive there is paper present when in fact there is not.
The sensor is usually located center of the opening, can be a photo eye or a lever.
you might want to take it outside, wind at you back then blow it out.
Be sure it is unplugged before attempting any sort of repair.
Hope this is of some help.
Ed
Posted on Apr 20, 2009
I have a royal shredder modle MP220 the motor is running but it doesn't will not pull the paper in . I cleaned it out and still nothing .
It is possible the blades are running in reverse. If the motor is running and the blades are turning without putting paper in, check the position of the switch. The motor should not turn on automatically when repositioning the switch. Reposition the switch so the light is on, but the motor does not run. Then try to put in paper. I hope this helps.
Apr 19, 2014 | Royal 160MX Shredder
Royal shredder
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Jan 27, 2014 | Royal 160MX Shredder
Paper is not schreddering
Do the shredding blades turn??? If the motor runs but the blades dont turn then you have probably lost a gear. If the motor dosnt run in the forward direction you may have lost the PCB.
Once you can be more specific you can contact Royal at 1-800-524-0799 for parts assistance.
Nov 30, 2010 | Royal 160MX Shredder
My royal 160mx shredder quit feeding paper. It runs forward & backward when the buttons are pressed but will not feed the paper.
Have a look inside where you put the paper and see if the cutting blades are turning when the machine is running...if they are NOT, then you have probably broken or stripped teeth out of a gear inside...you will have to open it up to check, then you can contact Royal at 1-800-524-0799 for parts assistance.
Nov 14, 2010 | Royal 160MX Shredder
Makes a knocking sound and feeder will not work.
Sounds like you may have something broken in the "gear train" drive...open it up to check and contact Royal for parts at 1-800-524-0799.
Oct 22, 2010 | Royal 160MX Shredder
I have a royal shredder model 160mx. motor is
Check if its just dirty "eyes"...they are in the middle where you put the paper in; clean them with a soft cloth ( unplug the shredder first.)
If that dos'nt fix it then it could be defective "eyes" or the pcb...you can call Royal at 1-800-524-0799 for parts and prices.
Jan 12, 2010 | Royal 160MX Shredder
Thecutter stopped turning any ideas?
The cutter stopped turning..... did the motor stop turning.????
If the motor turns but the cutting blades don't turn then you have probably lost a gear/ or teeth in a gear.... open and check... you can call Royal at 1-800-524-0799 to get parts.
Nov 14, 2009 | Royal 160MX Shredder
160mx will come on but not pull paper
When you say the shredder comes on do you mean that the motor runs...if so can you see in the slot whether the cutting shafts are turning.??? If the motor is running but the shafts are not turning then you will have to open up the unit to see if you have lost teeth on a plastic gear...if so call Royal at 1-800-524-0799 for parts assistance.
Aug 10, 2009 | Royal 160MX Shredder
Royal 160MX Shredder Logo
378 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
