Question about Linksys Wireless-N WRT150N Router
Slow wireless internet connection for select PC's; fast for other
Linksys Wireless N WRT150N We have three laptops on the system wirelessly...all three have wireless adapters that are ABG compliant with two of the laptops newer than the third and are N compliant.
However the third older laptop is faster accessing the internet than the two newer laptops (which have more processing power!) And in many cases, the two newer laptops cannot access the internet due to "poor connection" when the older laptop sitting beside them has "good or excellent" connection.
This situation started about six months ago and I cannot figure it out.
What settings on the router set up could be causing this?
Thanks
  • Linksys Master
  • 4,338 Answers
Make sure that your wireless mode is set to "mixed mode".
Intermittent Connectivity:
NOTE:
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
Router says there is no internet connection..so my laptop cannot connect wireless. But there IS a connection, because my PC and Vonage are working.
unplug your linksys router count to ten plug it back in give it about a minute and check to see if the internet is working
Nov 12, 2009 | Linksys Wireless-N WRT150N Router
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
I have hooked it up as the instructions state but it will not find the internet, I am useing a hp laptop and am trying to go wireless, it is the vista system
No its not your windows system, try to check again your wireless router if the software firmware are installed properly in your PC. Also to configure it and connect your internet provider to the Router, which is automatically create its own Protocol Address or Obtain Address, even on Wireless connection. This is basic on Wireless Router to connect on the internet. Good luck!
Aug 04, 2009 | Linksys Wireless-N WRT150N Router
Slow wireless connection
802.11b standard runs at 11Mbps. If you can only get 1Mbps from the router, you need to check your signal strength and your network card. If your wireless NIC in the laptop is only 802.11, you will max out at up to 2Mbps.
Mar 19, 2009 | Linksys Wireless-N WRT150N Router
I have a WRT 150N wireless router. it is not putting out a network but i can connect to the internet with one of the lan line ports
Connect to the router via the admin screen and select the wireless tab. Check to see if wireless is set to disable or to a setting that is not compatable with your PC/laptop wireless card.
Hope that helps and thanks for using FixYa
Mar 07, 2009 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
257 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
