Question about General Electric WHDRE526EWW Top Load Washer
Washer leaking profusely when it drains and fills out
The bottom of the unit. Hose is tight and connected.
  • 9 more comments
  • otm1 Apr 20, 2009
    Where is the valve assembly located and how do we check and also how do we check the seal as well?
  • otm1 Apr 20, 2009
    You mentioned something about constant pressure....we had a problem the other day where we discovered that the plug was loose in the outlet and it kept running the washer through the same cycle we finally had to unplug it to let it reset it self and then run it again...also I noticed that it was set on an extra rinse cycle and once I took it off the extra rinse cycle and unplugged it and let it reset it worked fine again...could this make it leak?
  • otm1 Apr 20, 2009
    once you take the screws out how do you pop off the shell of the washer?
  • otm1 Apr 20, 2009
    We took the front off the washer and re plugged the washer in and turned it on and it over filled the water sensor is not shutting the water level off.....does this mean it needs a new water sensor? if so where is it and how is it replaced and does this have anything to do with the water valve assembly too?
  • otm1 Apr 20, 2009
    Would the tub seal go out after only being a little over a year old? how can we know for sure it's the tub seal and how do we replace it?
  • otm1 Apr 20, 2009
    how can we be sure about the tub seal is there a way to check for sure? also how do we replace it?
  • otm1 Apr 20, 2009
    Thank you so much for all your help. Do you happen to have a picture of the thermistor probe? or a basic description of it so my husband can tell which it is....is basic diaphram accurated sensor or does it look like something else he just needs a rough idea of what it looks like.
  • otm1 Apr 20, 2009
    The picture didn't show up can you please send the picture to my email otm@outsidethemargins.com maybe that will work better.
    Again, thank you so much for all your help!
  • otm1 Apr 20, 2009
    okay here it is otm (at) outsidethemargins.com
  • otm1 Apr 20, 2009
    This helped so much, thank you for all your help!
  • otm1 Apr 20, 2009
    Excellent help, thank you so much!!
  • 6,784 Answers
Hi, i recommend checking the water valve assembly just to make sure it is not the source. there are many reasons for this type of leak and they generally will start with an issue within the water valve Assembly.
Once you have inspected the water valve assembly and, if it is in good condition and no leaks appear to be exposed, it will most defiantly be the Tub seal.
Replace the tub seal accordingly.
Posted on Apr 20, 2009
  • 8 more comments
  • Michael Masters
    Michael Masters Apr 20, 2009
    the water valve assembly is located inside of this washer. you will have to disassemble the entire washer to gain access to the water valve Assembly and the tub seal as well. when replacing the tub seal, you will have to remove the tub from the enclosure.
    the fill hoses run directly in to the water valve assembly but, the assembly itself is inside of the washer enclosure.
    Just to be safe, here are a few CHECK MARKS that i would run before disassembling the washer..
    Using too much detergent • Use less detergent. Use less soap if you have soft water,
    in washer a smaller load or a lightly soiled load.
    Fill hoses or drain hose is • Make sure hose connections are tight at faucets and
    improperly connected rubber washers are installed. Make sure end of drain hose
    is correctly inserted in and secured to drain facility.
    Household drain may • Check household plumbing. You may need to call
    be clogged a plumber.
    Constant water pressure • Tighten hoses at the faucets and turn the water off after
    to the fill hoses at the each use.
    water source • Check condition of the fill hoses; they should be replaced
    every 5 years.
    If everything here checks out, proceed with the inspection of the water valve assembly and tub seal. you should see visible water marks around the seal(tub) if its coming from there.
  • Michael Masters
    Ok, this is true. if the water pressure isn't consistent, the water pressure sensor in the water valve assembly will become unstable and it will allow leakage. you can combat this by shutting off the water faucets after every use.
    concerning the disassembling process. this washer has a pattern that is used along with the fastened screws as well once all screws are removed and the top lid is removed as well, the side panels and rear panel are held together by clips or grooves.(the design is fitted together like a puzzle and the screws add support.
    Once all the screws are removed form the enclosure, you will have to separate the grooves form each other.
  • Michael Masters
    I seriously think its the tube seal.
  • Michael Masters
    Ok, in this case, the tub seal is not the issue. if the water valve sensor is malfunctioning and it is not sensing the water flow correctly, you will have to replace the water valve assembly. the sensor is integrated within the actual valve device and it will have to be replaced entirely.
    The over flow is the reason for your leakage. its not the tub seal as suspected earlier.
  • Michael Masters
    Ok, i have done some additional research and i have come to this conclusion. your washer has a unique setup and the actual sensor is called a Thermistor probe atc. this sensor works in unison with the water valve assembly to adjust its flow. the thermistor will have to be replaced in this washer. it is creating this overfill situation due top to its failure to operate correctly.
    This water sensor(thermistor probe atc) is located in the same proximity as the water valve assembly but it is not integrated and it can be replaced separately.i will list the part number below.
    THERMISTOR --- WH12X10251
  • Michael Masters
    I have located a parts store that has the sensor you will need to replace. the link is below. you can order here as well.
    CLICK HERE
  • Michael Masters
    Sure, i will post a picture below this text.
  • Michael Masters
    Please rate and god bless:)
  • Michael Masters
    The email address didn't quite work, could you re post once more please?
  • Michael Masters
    Ok, i sent a full diagram with details as well.
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
Leaking water on the bottom of the washer while washing. Could you please tell me what`is wrong with my washer.
Water leakage
1. Inlet hose loosely connected to valve---tighten hose connection
2. Drain hoses not tight on pump----tighten hose clamps
3. Broken hose---replace hose
4. Leaky gasket---replace gasket
5. Cracked housing---replace part
Sep 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer is leaking
sounds like you have a hose problem. are the hot and cold water hose connections tight? they may need new washers. if that is the problem turn off water valves,disconnect hoses and replace them with garden hose washers from any hardware store. re-tighten them snugly. just tight enough so they don't leak. if it only leaks while draining, replace the short hoses connected to the pump,located inside bottom of inside of washer.
Sep 16, 2010 | Kenmore 9781 Electric Laundry Center with...
Our GE WSERR417FOWW washer is leaking (profusely)
Any solution to your problem? I am searching because mine started the same behavior tonight. I hope that you found a solution, and would be willing to share it!
Thanks.
Jeff jeffyr2@verizon.net
May 24, 2010 | GE WJRR4170E Top Load Washer
My washer is keaking water on the front left side. I think when its draining. i had the new style top put on that stops water from spilling on to the floor when filling
check that your drain hose is tight pull machine away from wall and see if it leaks there during drain cycle if it is leaking here tighten connection/Also check that it is tight at the faucets as well
Jan 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking from bottom as soon as washer fills
I would request you to pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Thank You for contacting Fixya.com
Aug 03, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
I have a kenmore front load washer model number 4174104200 and water is leaking onto floor.
Can you describe WHERE the leak may be coming from? If the leak is coming from the front area of the washer, it may be the door bellow (rubber gasket), or the drain pump. You will need to open the door and pull back the folds in the rubber gasket and inspect for cracks or tears in the rubber. To inspect the pump, you need to remove the bottom panel under the door and look for any leaks inside the unit. The drain pump is in the front, directly under the wash tub. Also check all hose connections. If the washer is leaking from the rear area, check the fill hoses and drain hoses for cracks or holes. Make sure all hose connections are tight. The fill valve is another possiblity too. You will need to remove the top panel to view the valve to ensure it is not dripping. Please verify your symptoms and let me know. I hope this helps.
May 01, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
WATER LEAKING FROM UNDER THE WASHING MACHINE
follow the hose from where it connects into the washer.. take off that panel and pinpoint leak. more than likely a hose is unattached
Apr 15, 2009 | GE WWSE5200B Top Load Washer
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
General Electric WHDRE526EWW Top Load Washer Logo
90 people viewed this question
Top General Electric Washing Machines Experts
Sal De
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
